I have two Beolab 8000 and are thinking of connecting them to a Beomaster 3500/4500.
Can I just use the Power Link cables/connectors for this or ?
Yes, that is how it is done!
Hi kimasker,
Welcome to Beoworld! Yes, you just need two Powerlink cables like these: https://soundsheavenly.com/powerlink-8-pin-din-connection/20-272-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html#/9-length-18m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Hi Steve,
Thanks, why not use the Powerlink mk2 and avoid any nose?
Kind regalds,
Kim
Hi Kim,
My mk3 and mk2 cables are both wired correctly to avoid noise. The mk3 cables are thinner and cheaper, without losing any sound quality.
