Beolab 8000 and Beomaster 3500/4500
This post has 4 Replies | 2 Followers
kimasker
Posts 4
kimasker Posted: Thu, Nov 14 2019 10:35 PM
I have two Beolab 8000 and are thinking of connecting them to a Beomaster 3500/4500.
Can I just use the Power Link cables/connectors for this or ?
Millemissen
Flensborg, Denmark
Posts 14,680
Yes, that is how it is done!
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi kimasker,
Welcome to Beoworld!  Yes, you just need two Powerlink cables like these: https://soundsheavenly.com/powerlink-8-pin-din-connection/20-272-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html#/9-length-18m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
kimasker
Posts 4
kimasker replied on Fri, Nov 15 2019 2:32 PM
Hi Steve,
Thanks, why not use the Powerlink mk2 and avoid any nose?
Kind regalds,
Kim
Posts 2,165
Hi Kim,
My mk3 and mk2 cables are both wired correctly to avoid noise.  The mk3 cables are thinner and cheaper, without losing any sound quality.
Steve.
Page 1 of 1 (5 items) | RSS
