Hi
First post here - so please be gentle!
I have just bought a LG C9 55”, an Axiim Link WISA transmitter and 2 x BL17, 2x BL18 plus a BL 19 secondhand during the Black week.
Everything plugs in and works fine – but I still have a few question I hope someone can share their experience on.
1: I am missing a Center Channel Speaker – as 5.1 sounds pretty silly (movies without dialogue)
I am considering a BL 7.1 with a BL Receiver 1 as one option – but is looking for any experience on how they will integrate sound- and connection-wise
Other option could be a Klisch RW-34C or Axiim’s own Center Channel. Sharing of any experience with these units will be much appreciated.
2: There seems to be a slight Latency issue – and the LG user guide is not very helpful in how this can be countered
There is a AV Audio Adjustment under Sound – but the Help speak about a +/- setting, while the TV just has a numeric value.
I tried change the Sound Source from the Topset Box (a YouSee Humax box) from Bitstream to PCM and that seemed to help somewhat.
Best regards
gd61:Hi First post here - so please be gentle! I have just bought a LG C9 55”, an Axiim Link WISA transmitter and 2 x BL17, 2x BL18 plus a BL 19 secondhand during the Black week. Everything plugs in and works fine – but I still have a few question I hope someone can share their experience on. 1: I am missing a Center Channel Speaker – as 5.1 sounds pretty silly (movies without dialogue) I am considering a BL 7.1 with a BL Receiver 1 as one option – but is looking for any experience on how they will integrate sound- and connection-wise Other option could be a Klisch RW-34C or Axiim’s own Center Channel. Sharing of any experience with these units will be much appreciated. 2: There seems to be a slight Latency issue – and the LG user guide is not very helpful in how this can be countered There is a AV Audio Adjustment under Sound – but the Help speak about a +/- setting, while the TV just has a numeric value. I tried change the Sound Source from the Topset Box (a YouSee Humax box) from Bitstream to PCM and that seemed to help somewhat. Best regards
Well - if you are looking for a Stallone movie - without hearing his voice - this is the setup for you ;-)
Without a Center Front you are missing most of the dialogue - which sounds funny.
I changed the setup on the LG from 5.1 to 2.0 temporarily - so I at least can follow the plot!
Vince,
Please make sure you download the LINK app for iOS and Android. Update your LINK by going to Settings->Update.
This will enable audio mixing so the center channel content will be mixed into the two L/R main Loudspeakers. Email support@axiim.com for more questions.
Thank you,
James
Hi again
I can confirm what Hammej wrote:
Updating to latest SW version in the Link App does indeed enable the Center Channel to be mixed into the Front Speakers.
So it Sounds OK now - even when the Audio on the LG is set to 5.1 - which effectively is 4.1
Thanks to Hammej for the notification.
It also seems like the Latency íssue is gone - or at least has become very small.
If that comes from the SW update or my change from Bitstream to PCM, remains to be checked later.
I am though still interested in any experience with a Center Channel Speaker - with or without BLR1 - put into the mix
Regards
Uffe
If you are sitting dead center (and alone) in the hotspot between the two L/R speakers this workaround might be ok for you.
However, a phantom center channel (that is what you get) will never be the same as a good dedicated center channel.
You can get a BL7-4 for little money nowaday and adding a Receiver One would solve the problem.....if it is a problem for you, of course.
Wiuld match the BL18’s well.
Millemissen:If you are sitting dead center (and alone) in the hotspot between the two L/R speakers this workaround might be ok for you. However, a phantom center channel (that is what you get) will never be the same as a good dedicated center channel. You can get a BL7-4 for little money nowaday and adding a Receiver One would solve the problem.....if it is a problem for you, of course. Wiuld match the BL18’s well. MM There is a tv - and there is a BV.
He agrees - but just doesn't think we'll get one anytime soon.
vlohjr1: Millemissen: If you are sitting dead center (and alone) in the hotspot between the two L/R speakers this workaround might be ok for you. However, a phantom center channel (that is what you get) will never be the same as a good dedicated center channel. You can get a BL7-4 for little money nowaday and adding a Receiver One would solve the problem.....if it is a problem for you, of course. Wiuld match the BL18’s well. MM There is a tv - and there is a BV. That’s why we need a wisa soundstage equivalent for this We’ll keep waiting
We’ll keep waiting
I just wanted to give a quick update on progress.
After good help from James at Axiim - the 5(4).1 setup worked fine, while i was waiting for a centre speaker.
I tested the BLR and BL 7.2 combo, but at the time it did not work.
I could not pin point the issue (LG, Axiim or BLR problem?), but it sounded awful, so I could return it with this option checked as "Tested - Not Approved".
I then looked around and settled for Klipsch RW-34C which seemed to do the job. But it took some work and waiting to get distributor to bring it to Denmark. Now it is here and it works fine. Speakers are not in final position - but sound (level and quality) is fine and I am a happy Bunny.
Still to be worked out are:
Sometimes updating the Axiim software is tricky and takes some attempts
Sound timing between speakers and TV sometimes seems drift over a longer session - easy fix by a reset
But I am sure that James and Axiim will get that worked out as well.
So all in all I am happy to have good powerful sound with flexible location - without introducing too many eye sores in the mix.
Hi. Still happy with the Axiim Link unit ?
HiYes - still happy.The upgrade issue seems to be linked to the IOS units used. Older iPhone failed - while a newer iPad Pro does the job in 1 or 2 attempts.The Axiim updates also seemed to have cured the timing issue - so my beef with the setup as of now, is when turning TV on - it sometimes misses the WISA speakers, and defaults to internal speaker.It is an easy fix (just switch to WISA on TV setup), and probably a LG issue more than a Axiim error.
Otherwise still a happy bunny.
I will share some of my experiences.
I have an LG C9 and 2xBL17 with the Axiim Link since december 2019.
Initial setup is surprisingly easy, basically plug and play, love it.
Latency is an issue. There is about a 100ms delay initially and it is noticeable in lips not syncing. I can not see a difference changing from Bitstream to PCM. Also I have all latest updates on TV, Link & speakers. Over time if the TV is on for many hours the latency will be really bad and it feels like it could be like a half second delay. Uplugging and replugging the Axiim Link USB cable resets the latency back to 100ms (which is still bad).
Using the Axiim Link connected to a computer will have virtually 0 latency, so there seems to be an issue with LG/Axiim not working well together.
Another issue that I had for a while was that my 5GHz WiFi and the WISA connection would interfere. Every time I turned on the TV, the Apple TV would disconnect from the WiFi and the speakers would connect and disconnect, switching between red and green light for like three minutes before everything stabilised. I tried setting different channels (36-48) on my router but it did not help.Changing the region in the Axiim Link app from "Europe" (which I should have since I'm in Sweden) to "USA" solved this issue for me. Maybe I'm using some illegal frequences now but it works : )
Hi guys, I did a factory reset on my TV and that seems to have solved the latency issue :D
Now I have a new issue though :P which might be more connected to my setup rather than a general issue.
I added two more speakers for a 4.0 setup. Now I have two BeoLab 17 and two Harman Kardon Citation Surround. The Axiim Link does a great job converting Dolby Digital 5.1 to the correct speakers and I'm happy with that.
As one can expect when having mis-matching speaker models, the output levels between the B&O and the HK speakers are not equal. Luckily there is a setting in the Axiim Link app to change "per speaker volume". The problem is that, depending on if I change the volume via the TV remote or the Axiim Link app, I need to put different settings the the "per speaker volume".
When changing the volume via the TV remote I need to put +10 on the B&O's and -10 on the HK's. This is as far as the sliders go in the app and still it's not quite a perfect match.
When I change volume in the app, the corresponding settings need to be 0 on the B&O's and +4 on the HK's. This gives a better match in terms of volume between the speakers.
For me this means I can no longer use the TV remote to change volume, which is such a bummer because it is so much more cumbersome to open the app, wait for the connection and fiddle with the small slider (with is very inconveniently placed in the bottom of the screen where the iPhone app-switcher touch surface is, so you need to be really precise so you touch the slider and not accidentally switch apps).
Nevermind, the latency issue is still there. Especially noticeable when using "Game" video mode. It's around 80ms now initially and after the TV has been on for around 8 hours it's at 400ms latency.
Hehe sorry for spamming but I'm gonna add one more thing to my list of issues :)
If I use the LG remote to change the volume, usually it works but sometimes it takes up to 10 seconds for the change to actually happen in the speakers. Using the app always works.
Hi I got LG NanoCell with A7 gen2 processor and similar B&O speakers. I’m not about to change from stereo to 5.1 in my setup, can someone please assist?
gd61: Hi First post here - so please be gentle! I have just bought a LG C9 55”, an Axiim Link WISA transmitter and 2 x BL17, 2x BL18 plus a BL 19 secondhand during the Black week. Everything plugs in and works fine – but I still have a few question I hope someone can share their experience on. 1: I am missing a Center Channel Speaker – as 5.1 sounds pretty silly (movies without dialogue) I am considering a BL 7.1 with a BL Receiver 1 as one option – but is looking for any experience on how they will integrate sound- and connection-wise Other option could be a Klisch RW-34C or Axiim’s own Center Channel. Sharing of any experience with these units will be much appreciated. 2: There seems to be a slight Latency issue – and the LG user guide is not very helpful in how this can be countered There is a AV Audio Adjustment under Sound – but the Help speak about a +/- setting, while the TV just has a numeric value. I tried change the Sound Source from the Topset Box (a YouSee Humax box) from Bitstream to PCM and that seemed to help somewhat. Best regards
Assist in what? What is it that is not working for you?
Hi, got some feedback from Axiim, apparently LG TV in Asia does not support WiSA 5.1 channel, Only 2.0 channel available, such a bummer.
Hi All
Sorry for adding to an old thread, but it seems the most relevant one.
I have a 7.1 HT system, all Beolab, and a new LG OLED G1 tv. My Klipsch wisa hub is getting old and need replacing.
I have tried in vain to buy a Axxim Q hub as a replacement, but it appear to only be available as part of a speaker package.
Is a Axxim Link, or a soundsend USB stick wisa transmitters an option, when you have multiple sources, some without volume control? ( i know they are only 5.1)
Are the issues with volume control and latency mentioned in this thread still a problem for the Axxim Link? My speakers certainly also need volume adjustment to avoid the 7.4 center speaker from overpowering everything else.
How is the Beolab speaker software updated? can the link/stick do it, or do I need to (again) take all the speakers/ R1 boxes to my B&O dealer?
ORCA99
