Beomaster 901
PetVik
Posts 2
PetVik Posted: Sun, Dec 8 2019 7:38 PM
Hello all!
I am new to the wonderful world world of vintage B&O and I have recently laid my hands on a Beomaster 901. The problem is that the left channel produces a significantly lower sound than the right channel. Otherwise the amp is working fine with a clear and nice sound.
Does anyone have a suggestion of what could be the problem? Should I change capacitors and trim potentiometers? I have tried to search the forum on similar issues but I have not found anyone having the exact problem that I have.
Thank you for any hints on what could be the problem and what could be done to correct it!
Best regards,
Peter
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Dec 8 2019 7:47 PM
Welcome to Beoworld!
Trimmers and capacitors, yes.
Always first steps when restoring older electronics.
PetVik
Posts 2
PetVik replied on Mon, Dec 9 2019 8:35 AM
Thank you for a fast reply, then I will change capacitors and trim potentiometers and see if that will cure the problem!
Best regards,
Peter
Page 1 of 1 (3 items) | RSS
