Hello all!
I am new to the wonderful world world of vintage B&O and I have recently laid my hands on a Beomaster 901. The problem is that the left channel produces a significantly lower sound than the right channel. Otherwise the amp is working fine with a clear and nice sound.
Does anyone have a suggestion of what could be the problem? Should I change capacitors and trim potentiometers? I have tried to search the forum on similar issues but I have not found anyone having the exact problem that I have.
Thank you for any hints on what could be the problem and what could be done to correct it!
Best regards,
Peter
Welcome to Beoworld!Trimmers and capacitors, yes.Always first steps when restoring older electronics.
Thank you for a fast reply, then I will change capacitors and trim potentiometers and see if that will cure the problem!
