CREATION 5 App on iPad
This post has 20 Replies | 5 Followers
HVD
Denmark
Posts 37
HVD Posted: Thu, Dec 13 2012 8:19 PM
I'v started using the CREATION 5 app to control my BS5 from my iPad.
1. The problem I encounter is that 95% of the time when I select ALBUM and then play a album, it only plays the first song, and then it stops. I would assume that it suppose to be able to play the entire album without pausing.
2. I also experience that the volume control on the left gets stuck with i.e.. 15, but I can still adjust the volume without any indication of the level it is at.
3. Under now playing, the bar showing for how long the track has been playing, it does not indicate how much played or whats left. Some times it does, but then gets stuck at i.e.. 2:10 played, but it continues to play.
Anyone have the same issues or know what to do about it?
Henrik
Rikard
Sweden
Posts 218
Rikard replied on Fri, Dec 14 2012 7:42 AM
Do you have mots activated?
If you have mots activated and recently have added alot of albums it takes time for the bm5 to organize the files. This happened to me with my bs5 when I added alot of music. After some time everything worked like a charm :)
I dont use the Creation app, I ues beo6 remote.
HVD
Denmark
Posts 37
HVD replied on Fri, Dec 14 2012 8:37 AM
yes I have MOTS activated.
I'v had my BS5 since 2009, and I have no problems with playing albums selected via BS5. It plays the album, and then starts on MOTS.
The problem is when using CREATION5. I think the problem is in the CREATION 5 software, but not sure. When I select an album, and start playing it, it only plays the first song on that album, and then it stops (PAUSE on my BS5 display).
gysse2004
Hellerup
Posts 192
gysse2004 replied on Fri, Dec 14 2012 3:38 PM
With Creation 5 you wont get it to work with MOTS. And another downside, your IPAD screen needs to be on all the time to play the next number. As soon as you turn it off, Beosound 5 will stop playing. With the Beo 6, MOTS is working like a charm. Hopefully B&O will come out with a software for IPAD or Iphone soon.
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
Griebel
Posts 416
Griebel replied on Sun, Dec 16 2012 8:21 AM
gysse2004:
That's actually a problem with others of this kind of App (Plugplayer, eLyric to name a few of them) when controlling BS5.
Fisp
Denmark
Posts 75
Fisp replied on Sun, Dec 16 2012 10:18 AM
gysse2004:
I do hope you are right. We really need an  iPad BS5 app developed for and by B&O.
To me the biggest downside is that none of these apps will play music gapless and then it is useless when listening to classical music.
Solex
Netherlands
Posts 103
Solex replied on Sun, Mar 10 2013 11:53 AM
When I put autolock on NEVER the connection with Beosound 5 and iPad  (creation 5) stops after some minutes.
i have MOTS on, is this the problem, or do i have to do something else on iPad
Beovision 10-46, Beo6, Beosound 5+ Beomaster 5, Beolab 12.2, Beolab 12.3, Beocom 6000
Millemissen
Flensborg, Denmark
Posts 14,680
Hi HVD,
you payed a lot of money for that crap-app - I would claim it back!
Greetings Millemissen
StUrrock
Posts 995
StUrrock replied on Sun, Mar 17 2013 8:57 PM
For the way B&O have neglected the BeoSound 5 owners with regards to apps they should be ashamed of themselves.
Solex
Netherlands
Posts 103
Solex replied on Mon, Mar 18 2013 12:06 PM
The Creation 5 app is updated to version 3.01.
Everything works perfect now.
No, I did not pay any euro for the app (Ipad Jailbroken)
HVD
Denmark
Posts 37
HVD replied on Mon, Mar 18 2013 4:11 PM
It now (finally) works with version 3.01 here as well. Smile
BeoHut
Posts 482
BeoHut replied on Mon, Mar 18 2013 4:51 PM
+1.
I was one of the lucky guys that downloaded this app for free ;-)
I'm very satisfied with this app in combination with my Playmaker. Works very well!
HVD
Denmark
Posts 37
HVD replied on Mon, Mar 18 2013 4:57 PM
I payed....... toooo much:-(
But works fine!
Solex
Netherlands
Posts 103
Solex replied on Mon, Mar 18 2013 6:14 PM
You can vind Creation 5 on the internet . Search for creation 5 ipa
Millemissen
Flensborg, Denmark
Posts 14,680
was that a joke Confused
Grrr! Mm
koning
holland
Posts 4,220
koning replied on Mon, Mar 18 2013 8:27 PM
No!
Millemissen
Flensborg, Denmark
Posts 14,680
Could someone then translate that stuff, please.
Grrr! MM
Solex
Netherlands
Posts 103
Solex replied on Mon, Mar 18 2013 8:47 PM
No that is 100% true.
Solex
Netherlands
Posts 103
Solex replied on Mon, Mar 18 2013 8:49 PM
With google translate you can translate it in english.
DoubleU
Posts 562
DoubleU replied on Mon, Mar 18 2013 9:28 PM
Are you promoting a cracked app? Embarrassed
koning
holland
Posts 4,220
koning replied on Mon, Mar 18 2013 9:36 PM
A real dutchmen pays for nothing....whahaha
Page 1 of 1 (21 items) | RSS
