I'v started using the CREATION 5 app to control my BS5 from my iPad.
1. The problem I encounter is that 95% of the time when I select ALBUM and then play a album, it only plays the first song, and then it stops. I would assume that it suppose to be able to play the entire album without pausing.
2. I also experience that the volume control on the left gets stuck with i.e.. 15, but I can still adjust the volume without any indication of the level it is at.
3. Under now playing, the bar showing for how long the track has been playing, it does not indicate how much played or whats left. Some times it does, but then gets stuck at i.e.. 2:10 played, but it continues to play.
Anyone have the same issues or know what to do about it?
Henrik
Do you have mots activated?
If you have mots activated and recently have added alot of albums it takes time for the bm5 to organize the files. This happened to me with my bs5 when I added alot of music. After some time everything worked like a charm :)
I dont use the Creation app, I ues beo6 remote.
yes I have MOTS activated.
I'v had my BS5 since 2009, and I have no problems with playing albums selected via BS5. It plays the album, and then starts on MOTS.
The problem is when using CREATION5. I think the problem is in the CREATION 5 software, but not sure. When I select an album, and start playing it, it only plays the first song on that album, and then it stops (PAUSE on my BS5 display).
With Creation 5 you wont get it to work with MOTS. And another downside, your IPAD screen needs to be on all the time to play the next number. As soon as you turn it off, Beosound 5 will stop playing. With the Beo 6, MOTS is working like a charm. Hopefully B&O will come out with a software for IPAD or Iphone soon.
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
gysse2004:As soon as you turn it off, Beosound 5 will stop playing.
gysse2004: Hopefully B&O will come out with a software for IPAD or Iphone soon.
I do hope you are right. We really need an iPad BS5 app developed for and by B&O.
To me the biggest downside is that none of these apps will play music gapless and then it is useless when listening to classical music.
When I put autolock on NEVER the connection with Beosound 5 and iPad (creation 5) stops after some minutes.
i have MOTS on, is this the problem, or do i have to do something else on iPad
Beovision 10-46, Beo6, Beosound 5+ Beomaster 5, Beolab 12.2, Beolab 12.3, Beocom 6000
Hi HVD,
you payed a lot of money for that crap-app - I would claim it back!
Greetings Millemissen
The Creation 5 app is updated to version 3.01.
Everything works perfect now.
No, I did not pay any euro for the app (Ipad Jailbroken)
It now (finally) works with version 3.01 here as well.
I payed....... toooo much:-(
But works fine!
You can vind Creation 5 on the internet . Search for creation 5 ipa
was that a joke
Grrr! Mm
No!
Could someone then translate that stuff, please.
Grrr! MM
No that is 100% true.
With google translate you can translate it in english.
Are you promoting a cracked app?
A real dutchmen pays for nothing....whahaha
