Beomaster 6500 - entering FM frequency
This post has 8 Replies | 2 Followers
lev1945
Posts 2
lev1945 Posted: Mon, Dec 16 2019 12:31 PM
I understand to tune the radio using BL1000 you press GOTO+enter 4 digits for the FM band like 1000 for 100.0 MHz+STORE, then preset station number and STORE again
But how do I enter a three digit frequency like 95.5 MHz? Pressing 995 does not work, same with 0995 or 9950. So how this is done correctly?
jojoe
Posts 13
jojoe replied on Fri, Jul 24 2020 4:37 PM
hI LEV1945,
I've got exackly the same problem with my BEOmaster 7000. Did youz ever find out how?
kindly regards
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Jul 24 2020 4:48 PM
I seem to remember you don't have to press STORE to tune in, just wait a second or two after keying in the three digits.
First when you want to store the station on a preset, press STORE and the preset number and STORE again.
jojoe
Posts 13
jojoe replied on Fri, Jul 24 2020 5:01 PM
 Martin,
yes , that's how it worksSmile
thanks again!
Jojoe
lev1945
Posts 2
lev1945 replied on Fri, Jul 24 2020 5:51 PM
And what about the station mumber
, how you store the frequency under a specific station number?
Filip
Copenhagen, *Denmark
Posts 72
Filip replied on Fri, Jul 24 2020 6:19 PM
Press Go To, then number of channel and Store, AFAIR.
jojoe
Posts 13
jojoe replied on Fri, Jul 24 2020 8:35 PM
complete sequence:
You first enter the frequency xxxx ( Go To xxxx without comma ), when found: (STORE  station number STORE )
jojoe
Posts 13
jojoe replied on Sat, Jul 25 2020 1:20 PM
jojoe:
complete sequence:
does anybody know how ,if possible,  to display the selected radio frequency on a Beomaster 7000/6500 ?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Sat, Jul 25 2020 6:45 PM
Not possible. Only visible on the MCP.
Page 1 of 1 (9 items) | RSS
