I understand to tune the radio using BL1000 you press GOTO+enter 4 digits for the FM band like 1000 for 100.0 MHz+STORE, then preset station number and STORE again
But how do I enter a three digit frequency like 95.5 MHz? Pressing 995 does not work, same with 0995 or 9950. So how this is done correctly?
hI LEV1945,
I've got exackly the same problem with my BEOmaster 7000. Did youz ever find out how?
kindly regards
I seem to remember you don't have to press STORE to tune in, just wait a second or two after keying in the three digits.First when you want to store the station on a preset, press STORE and the preset number and STORE again.
Martin,
yes , that's how it works
thanks again!
Jojoe
And what about the station mumber
, how you store the frequency under a specific station number?
Press Go To, then number of channel and Store, AFAIR.
complete sequence:
You first enter the frequency xxxx ( Go To xxxx without comma ), when found: (STORE station number STORE )
jojoe: complete sequence: You first enter the frequency xxxx ( Go To xxxx without comma ), when found: (STORE station number STORE )
Not possible. Only visible on the MCP.
