Dont say anything....
This post has 195 Replies | 1 Follower
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
Craig Posted: Mon, Dec 16 2019 7:02 PM
A BM5000 fell into my lap....what could I do?
Craig
Posts 2,040
Silver Member
It was staring out of an add on Ebay like a puppy in a rescue shelter...….
Craig
Posts 2,040
Silver Member
A number of switches are jammed into the selected position and its full of debris, but they all are after this length of time....and what is one to do, cant just ignore it....
Craig
Posts 2,040
Silver Member
Why am I calling it a BM5000.....Beolab would be more appropriate
Craig
Posts 2,040
Silver Member
These will have to go to Frede…….expensive but its the only way.
Craig
Posts 2,040
Silver Member
With the panels removed the selector switches freed up nicely, switched everything off and after a visual inspection revealed nothing obvious decided to connect up the variac and see what a little power does...….
Craig
Posts 2,040
Silver Member
Craig replied on Tue, Dec 17 2019 5:49 AM
And the answer is nothing....no signs of life and no current pull as the variac was would up, fuses checked out fine...….connections into the voltage selector switch also look fine, will check this out in due course.
Craig
Posts 2,040
Silver Member
Couple of measurements inside revealed no power was arriving at the voltage selector, inspection of the power cord showed the reason for this, a slight nick in the outer sheath.....when pulled apart discovered a break in the live side, the insulation is very flakey, peeled back far too easily. Will be replaced with a new length.
Craig
Posts 2,040
Silver Member
This time I powered up I was rewarded with a current pull of around 140mA, quite happy with that...
Craig
Posts 2,040
Silver Member
No power on lamp however.....inspection revealed a broken filament, replaced it with a spare 60v 5w and when powered back up got a nice glow.
Craig
Posts 2,040
Silver Member
Decided to check the quiet current voltage before powering down, I feel it's a good sign if these readings are healthy...
Craig
Posts 2,040
Silver Member
Both look pretty good to me....wont do anymore powered up testing, time to start the dismantle and clean up, these units have a distinctive smell about them, not burning of course...more an odour of old electronics, Ok I'm a bit strange ;¬)
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Tue, Dec 17 2019 8:30 PM
I do love these types of threads!! Big Smile
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
9 LEE:
Me too!  I do admire Craig's patience.
Regards Graham
Søren Mexico
Mexico City
Posts 6,411
joeyboygolf:
9 LEE:
I am only a member of Beoworld to follow Craigs threads Big Smile
Craig
Posts 2,040
Silver Member
I'm only too pleased to entertain the other members who contribute so much to this site Yes - thumbs up……looking over this unit a little closer I noticed this piece of folded paper wedged in behind the shield and the capacitors....
Craig
Posts 2,040
Silver Member
Thinking perhaps it contained some dark secrets I removed it only to find it was completely empty....seems it was only there to prevent the shield from touching the can of the capacitor which isn't to well insulated on the end, the shield did spring hard up against the capacitor when the folded envelope was removed...…...
beolion
Posts 485
beolion replied on Wed, Dec 18 2019 10:46 PM
Could be your lucky number in a funny lotto ;-)
Craig
Posts 2,040
Silver Member
Could be.....looks as good as any other number! used a compressed air line to blow away as much of the loose debris as I could, and will go after the transformer bay first
Craig
Posts 2,040
Silver Member
Transformer, voltage selector and fuse board disconnected and everything removed for a good clean...….
Craig
Posts 2,040
Silver Member
I have to say I have seen much worse...……..
Craig
Posts 2,040
Silver Member
These fellows are showing their age, got some new ones on order...….
Craig
Posts 2,040
Silver Member
Ready for a clean out...…..
Craig
Posts 2,040
Silver Member
Bottom plate removed, looks a little dirty but in good shape.....some corrosion around the feet area which will need wire brushing down to bare metal and painting
Craig
Posts 2,040
Silver Member
Now is probably a good time to replace the perished power supply cables...
Craig
Posts 2,040
Silver Member
Cleaned all the grime from the transformer wires and took it down to bare metal......Soren would frown if I didn't do so...
Craig
Posts 2,040
Silver Member
And following a couple of applications of primer.....opened a bottle Wink
Søren Mexico
Mexico City
Posts 6,411
Craig:
.opened a bottle
I always enjoy a well mixed Rum and coke after a job well done. Its just so relaxing leaning back with a drink in your hand admiring the work done and planning the next steps. Keep them coming Craig Cheers
Beo_Jean
QC, Canada
Posts 334
Beo_Jean replied on Fri, Dec 20 2019 11:49 PM
No you're not,
I'm just quiet... for now
Beo_Jean
QC, Canada
Posts 334
Beo_Jean replied on Fri, Dec 20 2019 11:53 PM
... replied to Soren about being the only one watching
Sorry
amsorepair
Posts 30
Love the love being put into this restoration Smile
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Dec 21 2019 8:00 AM
Always a pleasure to watch and read these threads.
I just wish I had time to do more.
New slider windows etc. on its way!
Craig
Posts 2,040
Silver Member
They are time consuming its true, so I do a bit at a time....its also very rewarding. Coat of primer for the inside of the bottom cover.
Craig
Posts 2,040
Silver Member
and following the removal of all the corrosion around the feet a coat of primer here too, I have tried to avoid the text as best I can...if you look closely you will see the front two right side struts (as you look at the picture) which support the transformer have parted company, cant imagine how this happened, would take a fair amount of force to do this. I don't think it will be a problem as the rest of the structure is still sound.....
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Sat, Dec 21 2019 10:34 PM
Søren Mexico:
Maker’s Mark bourbon on the rocks for me.
Great thread, Craig. I once rescued a pair of Beovox P45s that reminded me of a sad puppy. I know how you feel.
Craig
Posts 2,040
Silver Member
Minor modification to the brackets and replacements caps in place....
Craig
Posts 2,040
Silver Member
Bottom plate now complete with new feet......
Craig
Posts 2,040
Silver Member
Thought I would go for green hammerite for this one, so I don't get it confused with Sorens ;¬)
Craig
Posts 2,040
Silver Member
Removed the bracket assembly to get better access to the power switch.....its a bit grubby too
Craig
Posts 2,040
Silver Member
Top of the switch assembly...power,test and speakers 1 & 2
Page 1 of 5 (196 items) 1 2 3 4 5 Next > | RSS
