Hard to say much from afar.
Did you try to connect the BS3000 and the BV10 directly without having the converter in the mix....just as a test?
This could show if there is a fault in the 3000.
If possible use a ML cable in one piece.
Remember to make the right options for that setup....and don’t forget to reset, when the test is made.
Mostly ML issues are related to faulty cables/cable connections, that suddently appear...without any forewarnings.
Maybe you should check that junction box first!
Did you restart the converter after handling with the ML?
Did you disconnect the ML plug from the converter while working on the ML?
Anyway....nice that it helped to reinstall the junction box.
Millemissen:Did you restart the converter after handling with the ML? Did you disconnect the ML plug from the converter while working on the ML? Anyway....nice that it helped to reinstall the junction box. MM There is a tv - and there is a BV.
