Hi All,
We are the proud owners of an ex-demo BV10-46. We've had the TV now for two weeks and it's fabulous, but for some reason it won't accept being set to Video Option 2, and the TV won't select any Masterlink-shared sources.
The TV will accept options 0, 1 and 4, but not 2 or 6. We have a BS9000 in an adjacent room set to audio Option 2, and this all worked nicely together with our BV7-40 Mk II (which we traded in) with both items set to Option 2, (i.e. we could select audio sources on the TV, and TV sources on the BS9000).
The dealer who sold us the TV has been out today to upgrade the TV software, but the problem persists and I get the impression that they're out of ideas. We're at the point of deciding wether or not to call the whole thing off and return the TV; it certainly doesn't look like it'll be working by Christmas.
Not sure if anyone else has faced a similar problem, but I'd be really grateful for any advice.
Cheers,
Simon.
Raeuber,
Thanks for the advice! I've checked the 'Monitor Information' page and, just as you thought, the System Module shows 'n/a'. I've forwarded this information to the dealer, so hopefully they can verify the problem....
I'll report back with the outcome of this problem - very frustrating. Thanks again for the information.
Regards,
simongdavies: I've checked the 'Monitor Information' page and, just as you thought, the System Module shows 'n/a'. I've forwarded this information to the dealer, so hopefully they can verify the problem....
There is very small chance a "reset to factory default" followed by disconnecting the TV from the mains for several minutes can bring the Sys-Module "back to life". "Reset to factory default" means, you're loosing all current settings, program lists, ect. ...
Well, our BV10-46 is now fully functional!
It was indeed the system module; a quick swap for a new module from Denmark and all is now well. My sincere thanks to those who helped identify the problem!
