By accident I found the following page: https://support.bang-olufsen.com/hc/en-us/articles/115000942169-How-do-I-distribute-sound-from-AirPlay-over-Multiroom. Unfortunately I do not find "APPLE" in the menu.
I can "push" airplay to selected NL products (e.g. Core), but I can not forward the stream via B&O Multiroom to another NL product (e.g Beosound 35).
I read the above link so, that this should be possible. But how?
After that:
You can distribute the airplayed sound (from the Core) either through the ‘Join’ function on the BS35 respectively the ‘Join’ command from a B&O remote to the device.....
......or you you can add the device to the ongoing session in the multiroom section of the Bang & Olufsen app.
Millemissen:After that: You can distribute the airplayed sound (from the Core) either through the ‘Join’ function on the BS35 respectively the ‘Join’ command from a B&O remote to the device..... ......or you you can add the device to the ongoing session in the multiroom section of the Bang & Olufsen app. MM There is a tv - and there is a BV.
steve1977:That’s great. Unfortunately, it doesn’t allow to mix an AP multi-room with an NL multi-room though (given required delay to activate above feature. Maybe B&O will add a feature to “tap” to join AP streams. This would solve my issue not being able to use “old” B&O through APE in multi-room whole maintaining the “tap to join” feature for new speakers.
Sandyb:You can tap to join other B&O NL products to an Airplay stream happening elsewhere For example, I often Airplay to my A9, and then tap to join my BS2, or either of my BV'S By APE, do you mean Airport Express? In which case, is it software updated to AP2? Anyway, you should be able to do what you are describing that you want
The choice is yours!
You can not mix AirPlay2 and the BeoLink distribution of an airplay session.
Find out, what suits you best.......probably AP2 as long as you depend on having the APE in the setup.
Millemissen:The choice is yours! You can not mix AirPlay2 and the BeoLink distribution of an airplay session. Find out, what suits you best.......probably AP2 as long as you depend on having the APE in the setup. MM There is a tv - and there is a BV.
Maybe I dont understand.
What is your APE connected to?
Surely the easy use case is to Airplay to an Airplay 2 enabled B&O speaker, and then just tap to join (or use the app) to ad other B&O NL speakers.
Its worked for me for ages, and no delay - or nothing obvious.
Anyway, perhaps I'm not quite clear on what you're trying do exactly, an your exact setup.
steve1977: Sandyb: You can tap to join other B&O NL products to an Airplay stream happening elsewhere For example, I often Airplay to my A9, and then tap to join my BS2, or either of my BV'S By APE, do you mean Airport Express? In which case, is it software updated to AP2? Anyway, you should be able to do what you are describing that you want I don’t think i can, but wish i’m wrong. Yes, APE is updated to AP2. I can play to an APE and a BS1 in-sync. But only as soon as i disable the feature that allows AP to be distributed via NL. Enabling this feature introduces a delay. So, AP2 to BS1 ans APE only works as long as i disable this feature :(
steve1977: Millemissen: The choice is yours! You can not mix AirPlay2 and the BeoLink distribution of an airplay session. Find out, what suits you best.......probably AP2 as long as you depend on having the APE in the setup. MM There is a tv - and there is a BV. My preferred scenario would be AP2 with B&O supporting “join” :)
I am with you 100% here, Steve. With the very limited input options currently offered natively by B&O, it seems counterintuitive that an Airplay source played to one speaker cannot be transported via B&O Multiroom to other NL speakers.
I hate to draw the Sonos-card, but they manage this functionality very well. NO LAGS.
For me as an Apple Music user, my preferred use case would be Airplay 2 to, eg., my Beosound 1 and a distribution of that sound via NL Multiroom to everywhere else in the house in perfect sync. Why shouldn't it be possible?
Am I missing something?
I Airplay all the time from my MBP/iPad/iPhone to one of BS2 / A9 MK2 / ATV.
From then, I can physically tap to join / join via BR1 / use B&O app to allow other B&O speakers / BVs.
If the problematic scenario is Airplaying to a non-B&O speaker, and then not be able to get B&O speakers to join via NL, then I get it.
But otherwise, it works for me, I dont get sync issues.
Occasionally the odd sync issue, but generally not.
StKong:I am with you 100% here, Steve. With the very limited input options currently offered natively by B&O, it seems counterintuitive that an Airplay source played to one speaker cannot be transported via B&O Multiroom to other NL speakers. I hate to draw the Sonos-card, but they manage this functionality very well. NO LAGS. For me as an Apple Music user, my preferred use case would be Airplay 2 to, eg., my Beosound 1 and a distribution of that sound via NL Multiroom to everywhere else in the house in perfect sync. Why shouldn't it be possible?
Sandyb: Am I missing something? I Airplay all the time from my MBP/iPad/iPhone to one of BS2 / A9 MK2 / ATV. From then, I can physically tap to join / join via BR1 / use B&O app to allow other B&O speakers / BVs. If the problematic scenario is Airplaying to a non-B&O speaker, and then not be able to get B&O speakers to join via NL, then I get it. But otherwise, it works for me, I dont get sync issues. Occasionally the odd sync issue, but generally not.
Exactly that is the point.
Airplaying to an APE uses the AP2 protocol and distributing that works fine as long as you stick to the AP2 protocol....which is supported by the B&O devices.
However, this can only be controlled ‘the Apple-way’ using the menu on iOS devices etc and adding AP2 speakers from there.
Join is using the B&O protocol - you can easily join what you play via AP on one B&O device from another or even from more B&O devices (Sandyb described howto).
But you cannot play to e.g. an APE and then join in on that (via the B&O streaming protocol) from a B&O device.
The AP2 protocol and the B&O protocol don’t work together.
As long as you want non-B&O AP2 capable devices in the mix, you must stick to the AP2 protocol, which means no joining.....whether you want it or not!
I distribute airplayed stuff all the time at home - but I only use B&O devices. I don’t use or even need AP2.
My two ATV4’s are never used to distribute AirPlay - they only receive when I am using one standalone.
StKong: With the very limited input options currently offered natively by B&O, it seems counterintuitive that an Airplay source played to one speaker cannot be transported via B&O Multiroom to other NL speakers.
I don’t get what you mean.
Basicly you can airplay anything to a B&O device.....and from there join in from other B&O devices.
What are you missing?
I agree, you can AirPlay 2 anything from an iOS device to any number of speakers without going through any B&O protocol. In my case if a B&O speaker does not have AirPlay built-in, I just make sure it is connected to an Apple TV (if connected to a TV) or an Apple AirPort Express. You can basically use any AirPlay 2 complaint streamer to do the trick. I also prefer the AirPlay 2/iOS user interface over the B&O App for multi-room. So, you only have a problem if you'd rather use the B&O App vs. Apple's user interface.
B&O in my life 😊:
Jaffrey2230:I agree, you can AirPlay 2 anything from an iOS device to any number of speakers without going through any B&O protocol. In my case if a B&O speaker does not have AirPlay built-in, I just make sure it is connected to an Apple TV (if connected to a TV) or an Apple AirPort Express. You can basically use any AirPlay 2 complaint streamer to do the trick. I also prefer the AirPlay 2/iOS user interface over the B&O App for multi-room. So, you only have a problem if you'd rather use the B&O App vs. Apple's user interface. TV Room : BL 8000, BL 2 connected to 65 Inch Sony A1E OLED TV Living Room : BL 6000, B&W PV1 connected to AirPort Express driven by AirPlay 2 Dining Room: BeoPlay A9 Mk2 Kitchen : BeoPlay P6 Bedroom : BL 6000, BL 11 connected to LG UST Projector and Apple TV 4K, room also has an Apple HomePod Travel : BeoPlay H4 3rd gen. 2020 plans: Add a BeoSound 2 to the office and upgrade living room BL 6000 set with BL 18
True. It would save a step. However, with Siri you can use voice to move/add any speaker in any room quite easily. However, it requires an iOS or HomePod in voice range. Hopefully B&O can improve their app and software to the point where it is as refined as say SONOS. Until then, Chromecast with Google Voice or AirPlay 2 with Siri are probably the best options.
Jaffrey2230: True. It would save a step. However, with Siri you can use voice to move/add any speaker in any room quite easily. However, it requires an iOS or HomePod in voice range. Hopefully B&O can improve their app and software to the point where it is as refined as say SONOS. Until then, Chromecast with Google Voice or AirPlay 2 with Siri are probably the best options.
If AP2 works for you, it might be the best option for you.
I guess if you are using AP2 to control your devices, you will have an iDevice in reach anyway!
Here is how to do this (using an iPhone):
https://youtu.be/joV_DdkJWWk
As for the very last part with the third party apps, this has changed or is about to change - it seems that Apple now (with iOS13) is more open for Siri controlling of non-Apple apps.
I think it would be best not to dream about the option for integrating a specific B&O/NL multiroom feature into the Apple eco system - that would require some heavy changes to how Apple does things.
I like this feature! Wondering how long B&O already is offering it.
In my setup I have made the experience that the synchronization is much better (no echo) when I stream to one speaker via Airplay and connect all other B&O speakers via B&O Multiroom.Compared to connecting all B&O speakers directly to the streaming device via Airplay 2, in this case I have a very low delay (= small annoying echo) between the B&O speakers.
Do you have similar experiences?
So I am fighting with myself. Using only one app (e.g. Deezer), steaming via airplay 2, but having a low echo OR using two apps Deezer and the B&O app to group my B&O speakers.
I have 2 Beolab sets connected to Apple TV’s, 2 to Airport Express, A9 and recent Beosound 2 with native AirPlay 2 support. I also have a strong Google wifi mesh. There is no delay. In fact I am so impressed with the way it works that I am thinking of ditching my Beoplay P6 altogether with a Beosound 1 as a portable speaker since it supports AirPlay 2 - just ordered it on Amazon!
Funny that in my case, getting the B&O App to play across multiple devices resulted in audio drop outs. Back in the day I bought two A6s for multi-room with an A9. I ended up selling the A6 because the wireless didn’t work well with the B&O App. At the time, AirPlay 2 wasn’t out and the user experience wasn’t great. Now I have developed a new found love for my old and new B&O gear. 🙂
Jaffrey2230:I have 2 Beolab sets connected to Apple TV’s,
Alsfeld: .......OR using two apps Deezer and the B&O app to group my B&O speakers.
Why two apps?
Can’t you access Deezer from within the Bang & Olufsen app?
Millemissen:Why two apps?
Main reason I do not use the B&O App is, because it does not offer Deezer „FLOW“ and „Music by Mood“ at least I did not find it. But perhaps it is as hidden as the Airplay distribution feature?
In general in my eyes the B&O App interface to Deezer and to DLNA is much too limited to really use and enjoy it.
I understand your reasons.
Personally I use the Spotify (Connect) app - even if it (with my setup/my devices) is pretty well integrated in the Bang & Olufsen app, I use two apps.
But I do not see, that as a problem!
When I use AirPlay, I use other apps too - e.g. if I want to listen to and distribute podcasts or I want to catch up on radio programmes, that I did not manage to listen to when they were originally aired.
Distributing AirPlay over the B&O multiroom has been supported for quite a long time.
This way I stay in the Bang & Olufsen app and can use the external/not integrated sources, whenever I need/prefer these.
With time you get a certain workflow - no big problems here.
Even if TuneIn and Spotify Connect are my main sources, I certainly would miss the possibility to distribute AP over B&O multiroom, if that was not possible.
P.S.
As for ‘FLOW/Music by Mood’......that is not the way I listen to (read: use) music - I am a dedicated album listener.
So, different user cases might call for different approaches to how you use your (B&O) gear.....and the app.
I have both Apple TV’s connected to BeoLabs when connected to TVs and AirPort Express when not connected to a TV. The AirPort Express DAC is really good. You could use an Apple TV in headless mode without a TV for audio, but you’ll need an external DAC between the Apple TV and Beolab speaker.
Wow, it took me 15 minutes to find the described Airplay functions in the deep deep setup menus.
Very well hidden B&O! Is this the Bang&Olufsen user experience to convince new customers to pay more money than for competitor products?
Where is the official Bang & Olufsen manual or website where I can find this kind of information and all new features offered over time?But probably B&O is ashamed of the user experience they offer to their customers, so they decided to hide (and not to communicate) all available features and offer their speaker as cheap and simple Airplay / Chromecast alternatives as all competitors do.
HH1971: Wow, it took me 15 minutes to find the described Airplay functions in the deep deep setup menus. Very well hidden B&O!
It took me five seconds to get that information (asking Google for it) from B&O - first hit.
https://support.bang-olufsen.com/hc/da/articles/115000942169-How-do-I-distribute-sound-from-AirPlay-over-Multiroom
Not enabling this feature as the default one is a decision made because many users/buyers may prefer to use AP2 when they have other non-B&O AP2 devices in the setup.
As you can read in the link, AP over NL and AP2 distribution will not work well together.....
.....and - really - it did not take me 15 seconds to find that option ;-)
HH1971:Wow, it took me 15 minutes to find the described Airplay functions in the deep deep setup menus.
Millemissen:https://support.bang-olufsen.com/hc/da/articles/115000942169-How-do-I-distribute-sound-from-AirPlay-over-Multiroom
thanks for the link.
But the questions I still have:1) where can I find the manual(s) that explains the complete set-up menu of my B&O equipment?2) where can I find all new features of the software / app / firmware updates available? (so that I do not need to follow / read all threads at this forum to get some overviews what technical features are available - when somebody by accident mention is or asking for)
But probably Bang&Olufsen is already in such a bad financial situation that there is not enough money to write a detailed manual and maintain an internet page to list and explain all software / firmware updates.
Unfortunately B&O tradition / culture is to hide information / detailed description of features available from their customers.
I never understood why Bang&Olufsen is doing it.
I could imagine the following reasons:
