S45 rubber
fkatze
Posts 92
fkatze Posted: Fri, Jan 10 2020 3:34 AM
Picked up some S45s amongst a bunch of stuff today (Beocentre 3500, Beocord 900) and the woofers look mostly ok, but the rubber has started to separate from the frame.  It doesn't look like a factory install - very crooked retaining brackets, but other that that seems to be OK.  Mid is a bit sticky to touch, but appears in good condition.
What's the recommended adhesive to repair this?
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
Craig replied on Fri, Jan 10 2020 9:03 AM
I wouldnt worry too much about the type of adhesive you use to re attach the rubber to the frame, general all purpose should do fine. I would rplace the cross over caps, Martin can supply you with kits...and confirm the cones and coils move freely in the magnet.
Craig
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Jan 10 2020 11:09 AM
And the mountings look original.
fkatze
Posts 92
fkatze replied on Fri, Jan 10 2020 1:19 PM
Thanks for the responses.  I'll get some kind of flexible adhesive and stick them back down.  Doesn't appear to be any rubbing when pushing down on that woofer.  I'll open the other one up tomorrow and have a look.  From what I was told most of this gear was in storage for some time.
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Sat, Jan 11 2020 12:39 AM
It’s been awhile since we’ve had a thread about these. Aren’t they the S45-2, and don’t both the woofer and phase link need a bead of epoxy around the magnet?
fkatze
Posts 92
fkatze replied on Sat, Jan 11 2020 1:16 AM
Rich:
These are type 6302 if that helps.  I haven't heard about needing to epoxy anything before...any further info?
I took the other cover off, the woofer surround appears to be still bonded so maybe only on the one I need to re-glue it down.  Will order caps with a bunch of other stuff as I get my list together.
John
Yorkshire England
Posts 104
John replied on Wed, Mar 4 2020 10:47 AM
With that type no I think you have S45, someone has replace the foam with rubber.  Maybe a bit of "Impact adhesive"  is needed where the rubber is parting from the speaker. Also follow the advice above about a bead of Epoxy around the magnet, before the magnet slips and jams the cone.
Dillen
Posts 13,191
Dillen replied on Wed, Mar 4 2020 11:27 AM
Beovox S45 Type 6302 has rubber surrounds.
Beovox S45.2 Type 6312 has rubber surrounds (same woofer as Type 6302)
Beovox S45 Type 6427 has foam surrounds.
The foam surrounds in Type 6427 will all have gone bad by now and must be repaired.
The rubber surrounds usually show no signs of age but it has been seen before that they can come lose in smaller areas like shown above.
John
Yorkshire England
Posts 104
John replied on Fri, Mar 6 2020 7:44 PM
I stand corrected, I did not know there were two versions of the S45. You learn something new every day.
Page 1 of 1 (9 items) | RSS
