Problems BS5/ BV10 - software?
This post has 52 Replies | 2 Followers
Rikard
Sweden
Posts 218
Rikard Posted: Thu, Dec 20 2012 2:18 PM
My set up:
BV10-46, all speakers connected to the TV.
BS5 connected with ML to BV10.
PS3 & Mac connected to the TV
Problem is:
Sometimes I can change volume on the BS5, sometimes not.
Sometimes when I change source from CD to TV the CD stops and BS5 goes black (as should)
Sometimes when I change source from CD to TV the CD continues..
I does not matter if it is radio or cd - to tv/ dvd/v.mem.
Very irritating! I have spoken to my dealer (they are a bit tired of me since I was not to satisfied with the tv and bs5 in the beginning). Anyhow, I spoke to them and they said that it was/is software failure and that the problem will continue until B&O release a new software..
I had the same setup with my first BV10 and a BC2 - that worked like a charm!
Anyone experience the same ? Any suggestions of solutions?
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Dec 20 2012 3:42 PM
Hi Rikard,
I have similar problems with my BV 10-40 that I use as link-tv. Main-rv is a BV 7-40 and BS 9000.
My dealer reported the problems to B&O one year ago. Although two software updates were released during 2012, the problemes are not solved. It's very frustrating because B&O is not able to develop a software without bugs since 3 years now!
Regards
Räuber
Rikard
Sweden
Posts 218
Rikard replied on Thu, Dec 20 2012 5:42 PM
Ok, so the problem is in the bv10?
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Dec 20 2012 6:30 PM
Yes, the problem is the bad software of the so called system module in BV 10.
I had replaced my BV 10 with my 15 years old MX 4002 for test purposes and all masterlink functions worked perfect!
Razlaw
Posts 4,345
Razlaw replied on Thu, Dec 20 2012 7:55 PM
I have a Beosound 5, Beosound 3000, and Beovision 10-40 in the same room connected by Masterlink. They are also connected to a Beovision 7-55 in another room. I have not noticed any of these problems.
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Dec 20 2012 9:19 PM
Hello Razlow,
is your BV 10 the linkroom tv in your setup?
Did you ever try to program a timer on BV 7 for playing a radio station from BS 3000 ONLY on your BV 10?
Regards
Räuber
Razlaw
Posts 4,345
Razlaw replied on Thu, Dec 20 2012 10:57 PM
As for link room, BV7 is the video master, BV10 is the slave. I have used the timer in the BV7 but only for music from the Beosound 5 and with the intention that both rooms turn on.
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Dec 20 2012 11:59 PM
Ok, Razlaw, could you please check the following:
- Set a play-timer on BV 7 for a special radio station (for example No. 2) on BS 3000,
- Set ONLY BV 10 to execute this timer.
When timer starts, you will recognize that BV 10 plays a radio station on BS 3000. But this radio station will NOT be the programmed station (No. 2), but the last radio station selected before on BS 3000!
The other software bug I had described in this thread:
http://archivedforum2.beoworld.org/forums/t/983.aspx
Can you confirm this bug? Hi couldn't get a solution for this problem until today, nor from my dealer neither from Beocare!
Thanks a lot for your help!
Regards
Räuber
Razlaw
Posts 4,345
Razlaw replied on Fri, Dec 21 2012 1:11 AM
I tried the radio programming as you asked. It worked fine. Radio turned on each time to programmed station, not the previous station. Programming was set so that only the speakers connected to the BV10 turned on. Those connected to the BV 7 did not turn.
I tested with having the timer turn on channel 1, then I turned it off and had timer turn on channel 2. I also selected a channel with the Beo 4, turned off with the Beo 4 and then had timer turn on to a different channel. Also had timer turn radio on in BV10 room while BV7 was turned on to DTV. DTV continued playing on the BV7, radio turned on in other room and to proper, different channel, than when it was last turned off.
Razlaw
Posts 4,345
Razlaw replied on Fri, Dec 21 2012 1:21 AM
I looked at your other problem in the other thread. I see you are using link tv. I do not use link tv so don't have any knowledge of that. Here in the US we do not have the ability to send tv picture/sound to a link tv. Thus my BV10 functions when I press DTV and it has its own satellite box connected to it.
The problem with this is the timer function in the BV7 will not turn the BV10 on as, I assume, the BV7 knows it can not send a picture to the BV10 so it will not turn it on.
I have found a work around by setting the internal play timer in the BV10's satellite box to to turn the box on to the chosen channel at the chosen time. In order to get the BV10 to turn on itself I have to set its option programming to make it Video Master in addition to the 7 being a Video Master.
When I did the radio test I did change the option setting on the 10 to make it the Slave, not the Master as I assumed that would more closely replicate your settings.
Rikard
Sweden
Posts 218
Rikard replied on Fri, Dec 21 2012 12:35 PM
Perhaps it is time to talk to my dealer and see if he has a BV7-40 in store so I can trade in my BV10-46. So the system can work as intended.. A bit smaller picture and a thicker tv.. My Mrs said that Im an idiot for even thinking that way..
In my book this has to be a known problem at B&O and they shuld make an effort in solving the problems either by trading in the tv for another one or solving the problem. Now when the TV is out of production there will not be anymore updates.. It is a pity that I did not know this in advance, then I would have selected anther tv than the BV10. I still love it, it looks great on our livingroom wall. But the problems - it should not be this type of problems with such expensive piece of equipment..
Another way of solving this types of problems is if the sales guys have more knowledge about the systems and can recommend "the right" product for their customers..
I know I can be picky..
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Dec 21 2012 1:13 PM
Razlaw:
Hi Razlaw,
I am surprised that the radio programming works properly with your equipment. With my equipment the correct radio station turns on only if I let execute the timer by BV 7 or Beolink passive, but not by BV 10.
Probably BS 9000 ist the reason for the behavior, because you have a BS 3000.
I discovered the following behavior that might be the reason for the timer problem:
If all units are in standby and I press directly a station number on Beo4 (RADIO must be shown in display), my BS 9000 turns on with this station number if I do so with my BV 7. If I do so with my BV 10, BS 9000 doesn´t turn on with this station number, but with the last radio station selected before. What happens if you press directly a radio station number on Beo4?
BTW: Which software do you have on BV 10 (I have build 227 and system module 50.06a)?
Regards
Räuber
Razlaw
Posts 4,345
Razlaw replied on Fri, Dec 21 2012 1:36 PM
Pressing nothing other than the station number, with Radio in the Beo 4 display results in the BV7 turning on to the last number, and the BV10 will not turn on at all. I only had a moment to try this morning before going to work. I will double check tonight and try to find the software number. I am forgetting the exact method right now of bringing it up.  It will take me a few trys to get it right.
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Dec 21 2012 1:51 PM
Razlaw:
Hi Razlaw,
for me the behavior is very annoying: If I press CD in linkroom (BV 10), I can hear CD from BS 9000 in linkroom. If I press then for instance DVD, I can watch a DVD from BV 7 on BV 10, but the CD is still working in BS 9000. If I press then STANDBY, BV 7 with DVD goes in standby, but still not BS 9000! So it happens that CD is workink the whole night long!
If you press LINK-AV (via LIST) DTV, can you hear the sound of BV 7 on your BV 10 (V.OPT = 6)?
Regards
Räuber
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Dec 21 2012 2:00 PM
Razlaw:
Please try it with your Beo4 and BV 7 and then with Beo 4 and BV 10. In my setup, with BV 7 the BS 9000 turns on with the selected radio station and with BV 10 it turns on with the LAST radio station.
You can find the software versions by pressing MENU, then mark OPTIONS, and then press 0 0 GO. Now the service menue will appear and software versions are shown under MONITOR, MONITOR INFORMATION.
Regards
Räuber
Razlaw
Posts 4,345
Razlaw replied on Fri, Dec 21 2012 6:42 PM
If I press CD in my link room, BV10, and then switch to DTV, (I do not have a DVD in link room)  Beosound 3000 turns off.
As for the LINK-AV, yes it works. I did not know that was possible. I was able to get both the sound from DTV on the BV7 and from the Oppo BlueRay connected to the BV7 in the link room through the BV10 and speakers attached to it. Switching to Radio in link room resulted in radio playing in link room and other source remaining on in other room. Switching to Link-AV source caused the link source to begin playing and Beosound 3000 to turn off and go dark.
Razlaw
Posts 4,345
Razlaw replied on Fri, Dec 21 2012 6:50 PM
With Radio displayed on Beo 4, and pressing nothing but a number button, BV7 turns on to selected channel, BV10 does not turn on.
Software version on BV10 if I am reading right numbers
Build 210
PW328   4.40a
FEP         4.36c
FEP Bootloader  00.03b
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Dec 21 2012 7:21 PM
Razlaw:
Build 210
PW328 4.40a
FEP 4.36c
If you heard radio with BV 10, then standby, RADIO is displayed on Beo4. And if you then press only a number on Beo4, nothing happens, nor radio with the selected channel nor with the previous channel? If so, it might depend on software build 210 (actual is 227).
/Räuber
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Dec 21 2012 7:30 PM
Razlaw:
Yes, that's ok, because with DTV you switch to a video source of BV 10, and therefore Beosound 3000 has to turn off. Same with my BS 9000. The problem appears if I switch to a video source of BV 7 (for example LINK DTV), then my BS 9000 doesn't turn off (but it should also turn off).
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Dec 21 2012 7:43 PM
Razlaw:
I am happy that you now know how to hear sound of BV 7 video sources with BV 10, sometimes LINK-AV-command is usefull. LINK-AV means you set a video source in audio modus, so you can hear the sound over masterlink.
If you press LINK DTV (BV 10), you will hear (and see) nothing, because you don't have antenna cable between BV 7 and BV 10. But I think DTV on BV 7 is active then, means BV 7 is still off but DTV is shown in display of BV 7. Is this correct?
Razlaw
Posts 4,345
Razlaw replied on Fri, Dec 21 2012 8:33 PM
Deleted
Razlaw
Posts 4,345
Razlaw replied on Sat, Dec 22 2012 1:07 AM
Raeuber:
Razlaw:
/Räuber
1.  press radio in room with BV10.  Radio turns on.
2. press standby, all turns off.
3. press number on Beo 4, i.e. 1, 2 nothing happens.
Must press Radio again to turn on.
Razlaw
Posts 4,345
Razlaw replied on Sat, Dec 22 2012 1:12 AM
Raeuber:
Razlaw:
Using the Link-AV function I can access the audio from my Oppo BlueRay which is in the other room with the BV7.  I think this isimilar to the situation where you are having the problem? The BV10 then plays the Audio from the BlueRay player. If I have the radio on and switch to Link-AV  DVD the sound from the Oppo plays in the BV10 room and the Beosound 3000 does shut down completely just as it is suppose to.
Razlaw
Posts 4,345
Razlaw replied on Sat, Dec 22 2012 1:17 AM
Yes you are correct, but I do not get any sound. Everything (10 and connected speakers) turns on and the BV7 says it has switched to DTV but no sound plays from 10 when I do Link-AV  DTV.   I do get sound if the from the 10 if the 7 is on.
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Dec 22 2012 10:47 AM
Razlaw:
Thanks, this is different with my BV 10 and BS 9000. Probably it's the reason for the timer problem.
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Dec 22 2012 11:00 AM
Razlaw:
Yes, in this case my BS 9000 also shuts down, because with RADIO and then LINK-AV DVD you switch from audio-modus (audio source BS 3000) to audio-modus (video source Oppo). In these audio- modus the sound is distributed via masterlink.
My problem is if you switch from a source in audio-modus to a source in video-modus or from a source in video-modus to a source on audio-modus (in video-modus the sound and the picture are distributed via antenna cable). Then the first source doesn't shut down.
Although you don't have antenna cable between BV 10 and BV 7, you can check this as descibed in my following post.
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Dec 22 2012 11:24 AM
Razlaw:
Ok, with LINK-AV DTV you only get the sound if BV 7 is on, because the source connected to BV 7 (DTV = satellite box) is only connected digital (HDMI) and not additional analogue (Scart). If you connect the source also via Scart, you will get the sound from BV 10 also if BV 7 is off.
BTW: If you connect your satellite box not only via HDMI but also via Scart to BV 7 (if your satellite box has also Scart output), you will be able to send picture to link tv (BV 10). I have done so with my Technisat receiver, so I can watch recordings stored on Technisat receiver in link room (BV 10). Of course you will need an antenna cable between BV 7 and BV 10 and the RF LINK converter.
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Dec 22 2012 12:08 PM
Hello Razlaw,
now here are the final tests you could please reproduce (starting situation: All in standby; all commands with Beo4 on BV 10):
1.
- Press RADIO: You will hear radio from BS 3000 through speakers connected to BV 10
- Press LINK DTV: You will get no sound, but BV 7 says it has switched to DTV
Question: Did BS 3000 turned off now? It should do so, but my BS 9000 is still ON!
- Press STANDBY: BV 7 turns off (DTV in BV 7 display disappears)
Question: If BS 3000 didn´t turn off before, is it still ON?
2.
Question: Did BV 7 turned off now (DTV in BV 7 display disappears)? It should do so, but my BV 7 is still ON!
- Press STANDBY: BS 3000 turns off
Question: If BV 7 didn´t turn off before, is it still ON (DTV in BV 7 display)?
3.
- Press LINK-AV DTV: You will still get no sound (because your DTV source is only connected via HDMI)
- Press STANDBY
Question: Is DTV still shown in display of BV 7 or did it turn off (red standby light)? It should turn off, but my BV 7 still shows DTV in display!
Thank you very much for your support!
Regards
Räuber
Razlaw
Posts 4,345
Razlaw replied on Sat, Dec 22 2012 2:31 PM
Raeuber:
Hello Razlaw,
1.
2.
3.
- Press STANDBY
Regards
Räuber
Test 1   Pressing Link DTV has no effect. Nothing happens.
Test 2  Pressing Link DTV has no effect. Nothing happens.
Test 3  Pressing Link DTV has no effect. Nothing happens.
Test 1  Pressing Link-AV DTV :   Radio Turns Radio On, Link-AV DTV turns radio and Beosound 3000 OFF, light is OFF. BV7 displays DTV. No sound from BV10.
Test 2 Pressing Link-AV DTV turns on BV10, BV7 displays DTV, no sound.  Press Radio, radio plays from BV10, BV7 turns off. Press Standby, BV10 and Beosound 3000 turn OFF, light on Beosound 3000 is OFF.
Test 3 Pressing Link DTV has no effect. Nothing happens. Pressing Link-AV DTV turns BV10 on, BV7 displays DTV. No sound. Standby results in all turning off.
A couple comments. BV7 does not display DTV, it displays Dish Sat as I renamed it for purposes of display, but that is just nomenclature.
Also, note that if the BV7 is turned on when I us the Link-AV function on the BV10, the sound from the video source connected to the BV7 is transmitted via Masterlink to the BV10, which recognizes it as an audio only source as the motorized stand does not turn to a video position.
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Dec 22 2012 3:27 PM
First of all: The motorized stand will NEVER turn to any position if you send a command from a linkroom. It also will NEVER turn if a timer is executed directly on BV 7. This is because of security: Christmas tree beside BV 7 and a turning motorized stand when you are not present!
Your tests with the LINK-AV DTV command are plausible for me.
But why on earth pressing LINK DTV has no affect and nothing happens? If I disconnect my antenna cable between BV 10 and BV 7, pressing LINK DTV achieves BV 10 turns on with (of course) no sound and image noise on the screen, on BV 7 there is DTV displayed. I think I have to meditate about this....
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Dec 22 2012 5:16 PM
deleted
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Dec 22 2012 5:24 PM
Hi Razlaw,
your BV 7 is in V.OPT = 2 and BV 10 in V.OPT = 6, correct?
The reason why LINK command doesn´t work on your BV 10 might be: On BV 7 the POWER SAVING modus (OPTIONS / STANDBY SETTINGS) has to be set to OFF?
So I hope the LINK commands (LINK DTV, LINK DVD, LINK VMEM, LINK TV) will work now (by pressing LIST on Beo4 until LINK appears in display and then DTV, DVD, VMEM or TV).
Regards
Räuber
Razlaw
Posts 4,345
Razlaw replied on Sat, Dec 22 2012 6:15 PM
Raeuber:
Not always true. I have done some playing around with option settings in an effort to get the timer on the BV7 to turn on the BV10 to DTV where the two are linked only by MasterLink. If I set both the 7 and the 10 to option 2, the timer in the 7 will turn the 10 on AND the motorized stand on the 10 turns it to the video position. When the timer turns it off, the motorized stand returns to standby position. You are correct that the 7 does not turn when activated by a timer.
Of course as there is no video connection between the two, just Masterlink, there is no image on the 10 as a result of the timer. However, this problem is solved as the 10 has its own satellite box with a timer so the satellite box is merely programmed to turn on and select a channel at same time as BV7 sends turn on command to the BV10.  In that way it is possible to have the BV7 turn both TVs on and off at set times with both TVS displaying the chosen channel.
Razlaw
Posts 4,345
Razlaw replied on Sat, Dec 22 2012 6:26 PM
Raeuber:
Hi Razlaw,
Regards
Räuber
Correct, BV7 is in V. Opt 2 and BV10 is V. Opt 6.
Standby settings were to turn off after 2 hours. I changed it to "OFF". Link still does not work.
Link-AV still works to turn the BV10, and display the appropriate source on the BV7 and turn on the connected device, such as the Oppo connected to the BV7 but no sound is transmitted. If the BV7 is then turned on the sound also begins on the BV10.
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Dec 22 2012 6:52 PM
Razlaw:
Raeuber:
Hi Razlaw,
Regards
Räuber
I didn´t meant the STANDBY SETTINGS on BV 7, but the POWER SAVING, which has to be set to OFF. If OFF, the red LED lights up in standby. If it´s set to OFF the LINK command should work, if not I have no further idea.
As I mentioned before, you will hear the sound of your Oppo although BV 7 is off if you connect the Oppo also analogue (via Scart or Cinch) to BV 7 (if Oppo has analogue output).
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Dec 22 2012 7:03 PM
Razlaw:
Very interesting, I cannot check this, because my BV 10 is wall-mounted.
Razlaw:
Very clever. But setting both TVs to option 2 is no "official" solution from B&O, because this way you have two video masters in your setup.
Razlaw
Posts 4,345
Razlaw replied on Sat, Dec 22 2012 7:29 PM
I know it is not an "official" solution. But, what is the harm? it works.
Also, I do not have a power saving function that I can find. All I have is 2, 4, and 6 hours and OFF under standby settings as you initially directed me to.
Where would the power saving function be if I do have it?
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Dec 22 2012 7:50 PM
Oh, I think you have a BV 7-55 Mk 1. The Power Saving is a new feature of BV 7-55 Mk 2 (3D) and BV 7-40 Mk 6 (3D).
I really don't know why LINK command is not working with your BV 10. Probably it has to be activated in OPTIONS menue of BV 7 and/or BV 10. Under CONNECTIONS you will find LINK.
Razlaw
Posts 4,345
Razlaw replied on Sat, Dec 22 2012 9:03 PM
Yes, you are correct. I have a MK1 7-55.
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Dec 22 2012 9:31 PM
I will reflect why LINK command doesn't work with your setup. Without this you can't check out the standby problem I have with my setup.
If you connect your BV 7 and BV 10 with antenna cable, you cannot distribute picture from BV 7 to BV 10 without working LINK command. I can't believe this is a fact of the US Beovisions.
Page 1 of 2 (53 items) 1 2 Next > | RSS
