Beosound Balance
This post has 440 Replies | 8 Followers
Mikipidia
Posts 2,169
Mikipidia replied on Fri, Mar 20 2020 4:22 PM
Exactly and all the others are CC or AP2 compatible too. Still confusing in the sense that i feel that statement should come with an * somewhere.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Fri, Mar 20 2020 5:30 PM
Hiort:
It is a "multiroom speaker" as long as you use Chromecast or Airplay.
Or put two in each room and switch it on manually Big Smile This is not how it should be marketed, its a shame imo. But bigger things to worry about. Keep healthy everybody!
Livingroom: BL3, BL11, BV11-46 Kitchen : Beosound 1 GVA, Beocom 2 Bathroom : M3 Library : A6, Beocom 6000 Bedroom : M5 Office : Beocom 2 Travel : Beoplay E8 2.0, Beoplay P2
Fansastic
Posts 768
Fansastic replied on Fri, Mar 20 2020 5:33 PM
Hiort:
Or put two speakers in each room and select it manually Big Smile it is not multiroom as it should be. Still a b.. shame imo. But bigger things to worry about these days. Keep healthy everybody!
Aussie Michael
Melbourne, AU
Posts 3,730
w5bno123:
As a rule of thumb we decided to only stock the GVA variants in our Ealing showroom and order the non GVA version when requested. FYI we have stock of the Balance which is now very limited or not available until the end of April.
Regards
Stuart
B&O Ealing
Good idea, considering you can just turn the mic off if you don't want it to pick up on your voice and then you can still use it to multiroom (not the beolink / network link multiroom).
Ulrike
Germany
Posts 174
Ulrike replied on Sat, Mar 21 2020 9:51 AM
Aussie Michael:
I can confirm that it works.
http://bogo.custhelp.com/app/answers/answer_view/a_id/1059308/~/is-it-possible-to-mute-or-disable-the-microphones-on-beosound-balance%3F-
suneetjulka
Posts 29
Steve at Sounds Heavenly:
Hi MM,
Yes, that is a good point, I will be doing some further tests very soon to confirm the best for use with a non-B&O TV via optical.  I'm just waiting for a call back from B&O Technical regarding minimum latency settings.
For stereo pairing, B&O have told me prior to the launch that you can cable into one speaker (analogue audio or optical) and then wirelessly link the second speaker.  In this case, the speakers would be placed either side of the TV.
Using a single speaker directly in front/below the TV would be interesting, as this appears to have the capability to give some measure of stereo spread from a single point.....again, further tests to follow asap.
Kind regards, Steve.
I had confirmation from my dealer that the line-in on the Balance is for audio sources only and cannot be used to use the Balance as a TV speaker, I have tried it with a toslink to digital audio cable and it doesn't work
The cable workshop, Leics, UK
Posts 2,165
The product spec. sheet on B&O's website (page 2 of the PDF) confirms that the Balance has a combined analogue audio and optical input via the 3.5mm jack:-
https://assets.ctfassets.net/8cd2csgvqd3m/fUerNPQEbfvLwY0eGmAnV/d4d2edd5c269e26a6df0d9abe59d1f93/PS_BeosoundBalance_All_EN.pdf
It may be worth checking the optical signal format that you are sending to the Balance if you aren't able to get this to work.
Steve.
www.soundsheavenly.com
suneetjulka
Posts 29
Hi Steve,
Thanks for the update and information, what should the optical signal format to the Balance be do you know and how do I check or adjust this?
I assume it has to be done from the TV?
Stay safe all.
Millemissen
Flensborg, Denmark
Posts 14,680
suneetjulka:
Hi Steve,
Stay safe all.
PCM up to 2 channels.
The speaker will not be able to decode (and play) any Dolby Digital format.
Set the output to PCM, not to Auto.
suneetjulka
Posts 29
Millemissen:
suneetjulka:
Hi Steve,
Stay safe all.
Hi...
Thanks for the advice.
I set it to PCM and it still doesn't work for me.
I hope this can be fixed by a software update or something?
Kind regards,
Suneet
Ulrike
Germany
Posts 174
Ulrike replied on Sun, Mar 22 2020 11:20 PM
suneetjulka:
I already have an optical audio cable from my old speaker system (which has the D shaped ends but also has connectors/adapters that would allow it to go into a 3.5mm port such as on the balance), is this all I need?
I would definitely test whether the cable is still ok. Optical cables can be sensitive ... if they are bent unnoticed, they may no longer work. One of the connections could also be damaged or dirty. I would try it out with a new cable.
For me it worked flawlessly at the first try. Definitely not a software issue.
Ulrike
Germany
Posts 174
Ulrike replied on Sun, Mar 22 2020 11:58 PM
Ulrike:
suneetjulka:
Or just like that :)
See if the toslink mini jack lights up red when the TV is switched on.
If not, either the cable, its connection, or the TV's connection is damaged.
neokaplanis
Posts 4
TOSLINK (2ch) should work via the jack- Line-In input section. It's a similar layout to any other Multiroom Product in Flex category. The TOSLINK is also volume regulated, meaning that you can control the volume from balance, even if the TV sends full scale signal (as most TVs tend to).
It would best to check with another device just for a sanity check, that the sound comes out from the optical as expected. Hope that helps :)
andy_js
Englandshire
Posts 223
andy_js replied on Fri, Mar 27 2020 4:34 PM
mbolo01:
Ulrike:
Bang & Olufsen always found a way to ensure that a product in the customer's home is preserved and functions for a long time
Not true for the BS Moment unfortunately Sad
I guess that's why they called it the Moment.
Duels
England
Posts 2,553
Duels replied on Fri, Mar 27 2020 4:40 PM
andy_js:
Big SmileBig Smile
Sandyb
Posts 2,186
Sandyb replied on Fri, Mar 27 2020 6:40 PM
Duels:
Should have been called the Beosound Never
DGRouge
Posts 36
DGRouge replied on Sat, Mar 28 2020 12:30 PM
When playing Deezer via Chromecast the ‘HiFi’- logo disappears in the Deezer app. Does this mean the Balance is unable to play in the highest HiFi quality? I am not having same issue with streaming via Chromecast to Essence and Core - here the HiFi logo remains on.
Giraffe
Posts 37
Giraffe replied on Tue, Mar 31 2020 10:08 AM
In case some people might be interested. I just came across this offering from Cosse in Germany (don‘t know this shop personally) with 25% off.
https://www.cosse.de/aktionen/lautsprecher-aktion/
Giraffe
BeoFrederic
Posts 276
Somewhere in this thread I believe I read that the Balance project was conceived 2 years ago.  This is consistent with my supposition when I first read about about the balance:  it's a response to Apple's HomePod.
HomePod took technology from the BL 90 and packaged it into a small, free-standing cylinder-shaped multi-room loudspeaker.  It features 7 tweeters in beam-forming array, each with its own amplifier.  An internal microphone measures room response and the speaker corrects the bass.  It can be voice controlled.  Buy two and you can configure a stereo system.  Etc.
No one's going to argue that the HomePod is the equal of the BL 90, (as no one would anyone argue that the BS Balance is its equal).  But HomePod, given the technology deployed and Apple's market presence, could only have delivered an unpleasant wake-up call in Struer.
The HomePod premiered at ~ $500 / speaker, less expensive now that there are rumors of an imminent 2nd edition.  The Balance is $2250 / speaker.
To be clear:  I love the brand; I hope the Balance can help carry them through this rough patch.
trackbeo
Posts 644
trackbeo replied on Fri, Apr 3 2020 11:26 PM
No, the HomePod premiered at $349/speaker.  Reduced to $299 in April 2019.  As of the Balance's release date, it was on sale at retailer Best Buy for $199. Today, Apple employees can buy one to work-at-home for $149.50.
HomePods are not nearly as residentially pretty as the Balance, nor do they have as natural-sounding bass, nor line-in.  Their location-awareness is forced automatic and not direct-able like the Balance.  Their singular misfeature is that you *must* create an Apple Home account and verify yourself via phone for mandatory 2-factor authentication, even if all you want to do is use them as AirPlay(2) speakers.  But at less than 1/10 the price of the Balance, they aren't too shabby-looking or -sounding! (Versus, e.g., the Sonos speakers which are rather plain.)
I too hope that Balance sells well, but I will be buying 2 HomePods and a Beosound Stage instead.  (Well, unless B&O raises its price, which they keep doing like clockwork despite every other electronics item decreasing in price over the past decade.)  I like the way Balance looks but just cannot escape my drive for value.
Chris Townsend
Qatar
Posts 3,531
It’s already on sale for £1,600.
I’m in an apartment now in Doha with very few plugs, so having one decent speaker appeals. I don’t mind the design but much prefer the more traditional B&O design looking Beosound 2 which is of a similar price.
I’m aware of the clever driver setup it has, but sound wise how much different are they in real life?
Cool
Mikipidia
Posts 2,169
it's a very big difference honestly, the sound is way fuller and a lot more powerful. But in the end if a BS2 is loud enough and your room is not too large, then it's more down to style imo. A BsB is much closer to an A9 than a BS2 is and can fill a much larger room/go way louder.
Chris Townsend
Qatar
Posts 3,531
Ok thanks for that. I’ve got quite a long living room that’s quite boomy if you like. There a very few furnishings in it able to calm down or absorb the bass, so I even have to turn down my A2 Active sometimes.
I don’t want loud, I just want better. Until my Eclipse arrives I’ve bought a JBL sound bar and complimentary subErm.. I put YouTube music on and it’s unbearable. Too much poorly times bass but that’s another story.
I enjoy your videosYes - thumbs up
Mikipidia
Posts 2,169
Thank you Big Smile
if bass is the issue, the balance is probably better on balance Stick out tongue
It has a more controlled bass and will probably also tune itself better to the space. With the BS2 the bass is simpler, it sort of  it what it is and you have a basic EQ. It works, don't get me wrong and I love mine, but if the style matters less than musical performance than the BsB wins every time.
BeoFrederic
Posts 276
trackbeo:
Thanks, trackbeo, you're correct of course.  I relied on memory; at my age, I should know better.
trackbeo:
Interesting.  Will the HomePods be used in combination with the Stage, and if so, how?
A final, kinda wild speculation on the (reputed) eve of the launch of the HomePod next gen.   Isn't it odd that Apple went out of its way include Dolby Atmos processing in the most recent ATV, but doesn't offer speaker system that could handle even 5.1?  B&O has most or all of the pieces to have a complete home theater system...but let's not imagine that Apple couldn't do the same.
trackbeo
Posts 644
BeoFrederic:
Only as a multi-room music system, not as TV audio with surrounds, which is impossible.  (Someday, we can hope?!?)  Specifically, AirPlay from an old version of iTunes (which can play to multiple AirPlay speakers) playing from the local music library.  AirPlay2 from anything else, but no reason to play to both at once, even though it's possible.  Also in my case, an iPad with Spotify, which app will only play to one at a time, because licensing.
suneetjulka
Posts 29
Hi All,
My Balance with GVA doesn't automatically switch to the line-in when I switch source, I have to manually unplug and reconnect the optical audio cable that goes into my TV each time I want to use the Balance as a TV speaker... is this the same for everyone or should the Balance be switching automatically?
Also, how are people using the favourite buttons?  I need some ideas other than setting radio stations as the favourites.
Finally, is it possible to stereo pair a Balance with another speaker such as BeoSound 1 or Beoplay M3?
If not, do we think B&O will make this possible as it would be a brilliant feature.
Stay safe all.
Regards,
Suneet
Sandyb
Posts 2,186
Sandyb replied on Sun, Apr 5 2020 11:50 AM
No, only a Balance will stereo pair with another Balance.
Same for the others - it only works with the same product.
I cant see how it makes sense to stereo pair mismatched speakers, each with their own different sonic characteristics.
Which is why it wont happen.
suneetjulka:
Hi All,
Stay safe all.
Regards,
Suneet
1990
Posts 521
1990 replied on Sun, Apr 5 2020 12:09 PM
suneetjulka:
For the NL-speakers you can make fixed "groups" of NL-speakers (no stereo pairing but mono pairing where a slave always follows a master) through the BLI Intelligence. But that can't be used as Balance isn't integrated (yet) into the BLI.
suneetjulka
Posts 29
suneetjulka:
Thanks for this... what are NL-speakers and what is BLI?  Excuse my lack of knowledge.
1990
Posts 521
1990 replied on Sun, Apr 5 2020 1:29 PM
I'm sorry Suneet!
The NL-speakers are the speakers that work on the "Networklink" Multiroom. So the M3/M5, A9, Core, Essence etc. All modern speakers. Except the Balance, which has launched on a new platform.
The BeoLiving Intelligence (BLI) is a home automator which integrates control of lights/shades/cameras with the B&O AV products. If you use BLI, you can use a separate app to control your music, lights, cameras etc.
Ferdinand
Malmö, Sweden
Posts 541
“Worlds best smart-speaker”
Link (in Swedish) https://www.ljudochbild.se/test/hogtalare/bang-olufsen-beosound-balance/?_gl=1*3oeul*_ga*YW1wLW9MbmtxMExxWF9zcGtoMXR6eERMemVNa3Q4QlhaRWUyVmdqS21Qb0ZNaEdQb3VqQ1RLOGZ1Q0RTTzZjLUhieVE.#lesvidere
There is a video as well linked to the article
AndriaStanley
Posts 3
Hello to all,
I need advice. I read this review and I am little confused. Can you tell me please what is difference between Beosound Balance and Beosound Balance with the Google Assistant.
Waiting for your reply.
Thank you
1990
Posts 521
1990 replied on Mon, Apr 20 2020 5:02 PM
The version with GVA has a microphone built in to give voice commands to Google (just like you would do on a Google Home-speaker). Furthermore you'll have four short cuts on the top plate you can configure to send some often-used commands to the Google Assistant (like play playlist X, play radio Y or more general Google questions like if there is any traffic on your commute.
The non-GVA version doesn't have a microphone, but you still can use Chromecast and the Google Home app on your device to control the BS Balance. Just no voice assistant built in.
In future, the GVA-version will software update to also include the Amazon Alexa voice assistant.
1990
Posts 521
1990 replied on Tue, Apr 21 2020 5:13 PM
suneetjulka:
Hi All,
Hi Suneet,
Do you have any news on this issue? Can you fix the volume for the line in? I’m thinking about getting a Balance too but want to connect it to an older Masterlink product via line-in.
Posts 2,165
Hi 1990,
If you use a Powerlink output from the older product to the Balance, you can use the volume control of the older system to adjust the speaker level.
A cable like this is all you need from a Powerlink socket to the Balance: https://soundsheavenly.com/music-output/177-2544-powerlink-to-beosound-balance-stage-core-edge-and-shape-cable-link-your-legacy-bo-audio-system-to-your-new-bo-speaker.html#/2-length-1m
Steve.
1990
Posts 521
1990 replied on Tue, Apr 21 2020 7:48 PM
Thanks Steve! Do you have any info on the auto sense?
Posts 2,165
Hi 1990,
No sorry, I am not able to get to a B&O store to test this at the moment due to lockdown in the UK.  B&O haven't responded to any of my questions about this.
Are any Balance owners able to comment on whether the speaker can auto sense for a signal on the line input please?
Steve.
1990
Posts 521
1990 replied on Wed, Apr 22 2020 12:06 PM
I’ve asked my dealer too, let’s see. BTW, could you add a Balance as a speaker to an NL/ML converter? Is an RJ45<>3,5mm possible @Steve?
Posts 2,165
Hi 1990,
I haven't tried using the speaker directly with an NL/ML Converter, so I wouldn't recommend this.
Steve.
Page 9 of 12 (441 items) « First ... < Previous 7 8 9 10 11 Next > ... Last » | RSS
