How do you repaint a Beo4 ??
I have searched the forum, and cant find anything ? most Beo4 body's chip or get scratched, is there a workshop on how to repaint them ??, do you have to strip them back to bare metal ?
Ken
Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Paint brush or spray ? Have you done many of these remotes ?
I have a large section on the side that is bare metal, how can i fix this, or do I have to strip the side back to metal and repaint the side first, so that I get an even coat on the whole body.
Ken.
Thanks,
Have you got a Beovision 7-40mk5 ? Im looking for the Manuels ?
Strange that no one else on the forum has ever painted a Beo4 ?
not here but there is a dealer on ebay ....
https://www.ebay.de/itm/Bespoke-Bang-amp-Olufsen-b-amp-o-beo4-Fernbedienungen-Charakter-Print-Titan-12-/303239644703?nma=true&si=9V2X3oH7AlnP1JEWdUoBlny2WI8%253D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557
good luck
Still no dealer thats ever repainted or touched up a Beo4 ?
Strange, maybe it was cheaper for them to buy a new body ?
You know, let's have a different approach: Stop seeing it as a B&O pricey icon and just see it as a piece of metal.
Bramble told you: just sand it and spray it. It will always be better (even if you're clumsy) than peeled paint.And if first shot isn't good enough, sand it and spray it again, it's just Bare metal, you're not cutting or carving it.Even if the paint do wear quickly you'll be able to do it again when needed.
As long as you take care of protecting electronics which is quite easy, there's no problem in trying.
Hope this helps.
simple as can bee.
sand paper 200, car primer in spray, matt black car paint in spray...i done number of them with no problem.
Thanks for the tips, I like the idea of using a primer to give it a key, is the car primer and paint, thinner based, white spirit or water ?
