does anyone know the equivalent name for what became V.AUX in later models of BEO 4?
regards
Torsten
V.AUX is equal to DTV2 on the newer versions.... and SHIFT TV if you have a Beolink 1000
Søren
Hi Sören,
Thanks. But what would it be on a Beo 4 that doesn't have V.AUX in it config? When trying to Add it, I can't as it isn't in the list of commands to add.
cheers
Hi Torsten
if you don’t have V.AUX under list you should be able to add DTV2 instead
unfortunately I have neither option...
So maybe you have SHIFT in the list -
if yes, might be a good idea to try SHIFT TV on BEO4, as Søren suggested.
Just a guess...
Stefan
tnx - will try that.
tb59427: unfortunately I have neither option... cheers Torsten
That´s strange… I have 4 Beo4,
2 SAT versions, SW 5.0 EE 6.0
1 DTV version, SW 5.0 EE6.1
1 Joystick version, SW 7.0 EE0,62.
All 4 have V.AUX as option and the newest one also have DTV2,
What version do you have (Press GO and MENU at the same time and then LIST
Yes, strange - maybe a Hotel version...?
All very strange.Tried Søren's suggestion to figure out the SW version of my BEO4. Didn't work. But funny enough I now had V.AUX as a selectable Source in the "Add?" menu. Dunno - bit strange. Anyway it works now - thanks guys.
