V.AUX on an old BEO 4
This post has 9 Replies | 0 Followers
tb59427
Posts 68
tb59427 Posted: Mon, Feb 3 2020 7:57 PM
does anyone know the equivalent name for what became V.AUX in later models of BEO 4?
regards
Torsten
Soren
Denmark
Posts 115
Soren replied on Mon, Feb 3 2020 10:14 PM
V.AUX is equal to DTV2 on the newer versions.... and SHIFT TV if you have a Beolink 1000
Søren
tb59427
Posts 68
tb59427 replied on Tue, Feb 4 2020 2:31 AM
Hi Sören,
Thanks. But what would it be on a Beo 4 that doesn't have V.AUX in it config? When trying to Add it, I can't as it isn't in the list of commands to add.
cheers
Torsten
Soren
Denmark
Posts 115
Soren replied on Tue, Feb 4 2020 6:36 AM
Hi Torsten
if you don’t have V.AUX under list you should be able to add DTV2 instead
Søren
tb59427
Posts 68
tb59427 replied on Tue, Feb 4 2020 7:54 AM
unfortunately I have neither option...
cheers
Torsten
stefan
200 miles from Struer
Posts 2,920
stefan replied on Tue, Feb 4 2020 11:23 AM
So maybe you have SHIFT in the list -
if yes, might be a good idea to try SHIFT TV on BEO4, as Søren suggested.
Just a guess...
Stefan
tb59427
Posts 68
tb59427 replied on Tue, Feb 4 2020 11:45 AM
tnx - will try that.
Soren
Denmark
Posts 115
Soren replied on Tue, Feb 4 2020 3:43 PM
tb59427:
cheers
Torsten
That´s strange… I have 4 Beo4,
2 SAT versions, SW 5.0   EE 6.0
1 DTV version,  SW 5.0    EE6.1
1 Joystick version,  SW 7.0 EE0,62.
All 4 have V.AUX as option and the newest one also have DTV2,
What version do you have (Press GO and MENU at the same time and then LIST
stefan
Posts 2,920
stefan replied on Tue, Feb 4 2020 4:40 PM
Yes, strange - maybe a Hotel version...?
Stefan
tb59427
Posts 68
tb59427 replied on Tue, Feb 4 2020 7:53 PM
All very strange.Tried Søren's suggestion to figure out the SW version of my BEO4. Didn't work. But funny enough I now had V.AUX as a selectable Source in the "Add?" menu. Dunno - bit strange. Anyway it works now - thanks guys.
cheers
Torsten
Page 1 of 1 (10 items) | RSS
