Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Hallo, I have one and the cable with plug only for use with almost any eye. Cheers, Kai
I think the phono style jack will be fine for an IR eye without auto-contrast. The phono style jack supplies 5V, data and ground, and I think that is all that is required.
EDIT; Pages 121 and 123 refer: https://beointegration.com/uploaded/EN-BeoLink-handbook-v1-9.pdf
Yes, 3.5mm plug will work. With the 9 pin Dsub, you get the green and red power status buttons working. As you aren’t using a B&O TV, the ambient light check will be of no use. I used to use a raspberry which would connect up to the serial port to switch the TV on and off (via HDMI CEC), so it saved having multiple remote controls.
I'm using the Phono style connection on my BS3 with LG OLED TV. Connected like this.
Stoobie
And here is the wiring diagram I used. Wired as per Beomedia.
