Beosystem 3 dvi type
This post has 5 Replies | 2 Followers
bramble
Posts 397
bramble Posted: Fri, Feb 7 2020 6:31 PM
If you were to add an ir receiver to that type of bs 3
1. Can you use the ir type with the phono style jack ?
2. Do you need to use the 9 pin type?
It will be used with a lg panel not a beovision
If it's the 9 pin....were can I get one.
Rgds
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Manbearpig
Posts 908
Hallo, I have one and the cable with plug only for use with almost any eye. Cheers, Kai
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Feb 7 2020 9:28 PM
I think the phono style jack will be fine for an IR eye without auto-contrast.  The phono style jack supplies 5V, data and ground, and I think that is all that is required.
EDIT; Pages 121 and 123 refer: https://beointegration.com/uploaded/EN-BeoLink-handbook-v1-9.pdf
frog
Camberley UK
Posts 624
frog replied on Wed, Feb 12 2020 7:46 PM
Yes, 3.5mm plug will work. With the 9 pin Dsub, you get the green and red power status buttons working. As you aren’t using a B&O TV, the ambient light check will be of no use. I used to use a raspberry which would connect up to the serial port to switch the TV on and off (via HDMI CEC), so it saved having multiple remote controls.
Stoobietoo
Exeter, Devon, UK
Posts 692
I'm using the Phono style connection on my BS3 with LG OLED TV.  Connected like this.
Stoobie
Stoobietoo
Exeter, Devon, UK
Posts 692
And here is the wiring diagram I used. Wired as per Beomedia.
Page 1 of 1 (6 items) | RSS
