Essence MK2 turns off
This post has 11 Replies | 1 Follower
Razlaw
Posts 4,345
Razlaw Posted: Sat, Feb 8 2020 10:59 PM
Recently my Essence MK2 has begun turning off after 20 minutes. Any thoughts as to why this might be happening?
Thanks!
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Sun, Feb 9 2020 11:37 AM
I've had the same situation. Had this a few softwarereleases ago. But it stopped after newer releases. But now it has been happening for about 3 weeks ago, I think. Looks like they used older modified software again?
I have two Essence's mk2, which only one has this strange behavior. I use this one with a infrared remote receiver in the wall. Beo4 controlled. The other one I have is used with a Essence Remote or B&O's app, without problems.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Feb 9 2020 12:16 PM
two Essences, no issues  (both sw: 1.21.34087.134789577)
Beobuddy
Posts 3,972
Beobuddy replied on Sun, Feb 9 2020 12:21 PM
Both same software here.
Razlaw
Posts 4,345
Razlaw replied on Sun, Feb 9 2020 2:17 PM
Beobuddy:
I have the problem with one used with the app, or an Essence Remote.
Razlaw
Posts 4,345
Razlaw replied on Sun, Feb 9 2020 2:19 PM
Carolpa:
Same software as mine.
Razlaw
Posts 4,345
Razlaw replied on Sun, Feb 9 2020 4:12 PM
I think I solved the problem. I looked at the settings and Alarms were set as Enabled even though I have no alarms created. I changed the Alarm setting to Disabled and now it seems to be working fine.
Razlaw
Posts 4,345
Duplicate. Deleted.
Razlaw
Posts 4,345
Razlaw replied on Sat, Feb 22 2020 3:08 AM
Problem is definitely solved.
Beobuddy
Posts 3,972
Beobuddy replied on Sun, Feb 23 2020 1:10 PM
Still same behavior. Shuts down after 20 minutes . Checked settings (alarms/sleep/etc) in the B&O app and device itself (the black menus). Toggled them on and off. Doesn't make any difference so far. Always started with Beo4 with Radio command.
neilmarinez
Posts 1
Razlaw
Posts 4,345
Razlaw replied on Mon, Feb 24 2020 12:49 PM
Strange that one change in the settings completely solved my problem. I guess I was lucky. I turn mine on from either the app or an Essence remote. Works perfectly now once again.
Page 1 of 1 (12 items) | RSS
