Dear All,
I found on B&O web site the latest firmware version (15-01-18) for the BeoLab Transmeter 1.
I applied to my device.
Previous version was 192.5, now it's 204.1.
Firmware upgrade was done without any problem.
My system is:
Television BV7-55 -> BL Transmiter 1 (3 cables : front, surround and back)
- Front : 2 x BL18, FW: 189.8
- Surround : 2 x BL17, FW: 189.8
- Back : 2 x BL6000 via 2 x BeoLab Receiver 1, FW: 204.1
None of the speakers, either BL17 or 18, have been updated. Remark: the BLR1 is already at the latest version.
I don't see any clue in the debug file why upgrade was not done (look at the end of this post).
Of course, I followed the guide provided with the upgrade. And I tried three times. Before the last one I powered off all devices for, at least, 60 real seconds.
Thanks for your help.
Tux
FW version (file versions.txt):
Versions in zip-file:wpl_tx: 1.1.4.5310 (FEP: 1.15a), (DSP: 0.60a), (SUMMIT: 0204-01)BeoLab17: 1.1.5.6210 (FEP: 1.90a), (DSP: 1.96j), (SUMMIT: 0204-01)BeoLab18: 1.1.5.6210 (FEP: 1.90a), (DSP: 1.96j), (SUMMIT: 0204-01)BeoLab19: 1.1.5.6210 (FEP: 1.90a), (DSP: 1.96j), (SUMMIT: 0204-01)BeoLab20: 1.1.5.6210 (FEP: 1.90a), (DSP: 1.96j), (SUMMIT: 0204-01)BeoLabR1: 1.0.1.6211 (FEP: 1.00a), (SUMMIT: 0204-01)
Content of the debug file:
[00003084]Summit uart: Olympus FW Ver 204.1 (May 11 2017) Debug[00006755]Summit uart: ourceID = 9588[00006766]Summit uart: DeviceID = 0x16, BranchID = 0x02[00006813]MEMSTICK SW update check starting 00004534 Total 00004534 [00006835]Summit uart: System Data CHECKSUM Error...Calling I2CSlaveWriteRelease()[00006846]Error message from MCC 16 Seen since boot 1 [00006864]NumberOfSpeaker : 6[00006880]WPL : Event 0 received in state 0, new State 2[00007176]DSP booting from FEP![00007387]WPL : Event 2 received in state 2, new State 2[00007513]WPL : Event 5 received in state 2, new State 2[00007529]Summit uart: CHECKSUM Error...Calling I2CSlaveWriteRelease()[00013034]Summit beacon_cmd (time:5500) Status: 0x01[00013060]Summit uart: Quality Hop Enabled[00013420]Summit uart: SpeakerCount for Zone 0: 6[00013456]Summit uart: Restoring Slave 0... succeeded[00013491]Summit uart: Restoring Slave 1... succeeded[00013527]Summit uart: Restoring Slave 2... succeeded[00013560]Summit uart: Restoring Slave 3... succeeded[00013599]Summit uart: Restoring Slave 4... succeeded[00013635]Summit uart: Restoring Slave 5... succeeded[00013651]Summit uart: peakerCount for Zone 1: 0[00013667]restore speaker configuration Status: 0x01[00013678]Summit uart: SpeakerC5: 0[00013689]Summit uart: SpeakerC5: 0[00013726]master Mac Address 02 EA [00013846]Speaker ID 0 Configuration: Mac Address 02 EA [00013857]FW Version 189-8 [00013877]Speaker Mode=2 Slot=1 SpeakerDescription=0 BeoLab18[00013999]Speaker ID 1 Configuration: Mac Address 02 EA [00014010]FW Version 204-1 [00014027]Speaker Mode=2 Slot=2 SpeakerDescription=0 BeoLabR1[00014149]Speaker ID 2 Configuration: Mac Address 02 EA [00014161]FW Version 204-1 [00014177]Speaker Mode=2 Slot=3 SpeakerDescription=0 BeoLabR1[00014285]Speaker ID 3 Configuration: Mac Address 02 EA [00014300]FW Version 189-8 [00014316]Speaker Mode=2 Slot=4 SpeakerDescription=0 BeoLab17[00014438]Speaker ID 4 Configuration: Mac Address 02 EA [00014450]FW Version 189-8 [00014466]Speaker Mode=2 Slot=5 SpeakerDescription=0 BeoLab18[00014595]Speaker ID 5 Configuration: Mac Address 02 EA [00014606]FW Version 189-8 [00014623]Speaker Mode=2 Slot=6 SpeakerDescription=0 BeoLab17[00014643]WPL_TX SW updating Speaker 0 Not done[00014654]WPL_TX SW updating Speaker 1 Not done[00014670]WPL_TX SW updating Speaker 2 Not done[00014686]WPL_TX SW updating Speaker 3 Not done[00014697]WPL_TX SW updating Speaker 4 Not done[00014714]WPL_TX SW updating Speaker 5 Not done[00014730]MEMSTICK SW update check completed 00007919 Total 00012453 [00014746]MCONF : Event 21 received in state 0, new State 0[00015008]MISSING_speaker info cleared[00015027]WPL : Event 10 received in state 2, new State 2[00017579]Summit uart: SpeakerCount for Zone Quality Hop Disabled[00017625]system_shutdown_cmd Status: 0x01[00018161]MISSING_speaker info cleared[00018182]Sense status, PL=0 TOSLINK=0 LINE=0 USBB=0 USBA=0 ATI=0 ALWAYSON=0 TESTMODE=OFF PL/Line Switch=POWERLINK, ASSOCIATED
Hi All,
It seems to be a very complex question!
I still did not find the anwser.
If you have any suggestion, feel free to write them.
Take care,
lawrencejmcook:Isn’t the clue the CHECKSUM error?
Looking in my logs, the checksum error is present too, each time, and I don't see obvious signs of reasons not to update the BL in Tux logs :-(
I did two sw updates since I have my BLs 18/19, for the latest update I think I had to start it twice to succeed but I honestly don't remember the details. I also used the procedure later on to change the TR1 settings. i.e. to turn it into a WISA Switch.
@Tux: It seems that you have done what has to be done to update your products, did you observe your BL lights while attempting to upgrade?
