Essence or Beoremote One BT?
Thanks for your input.
How simple is it when you have just one source? Is it as simple as picking it up and clicking volume down?
In that case I’d say the Essence Remote might be ideal.
Otherweise I agree with Stuart.
And the Essence Remote can pair to Core all by itself? It has bluetooth? I’m a bit cautious because I already made the mistake of buying the wrong Beoremote 1...
Is the wheel more responsive when connected to the Core? With the Essence it’s quite buggy. Soketimes you need to press twice to start listening and volume control is also not smooth at all.
I have a second wheel controlling a Beosound 2 without any issues. So I guess it’s the Essence.
stampfki:Is the wheel more responsive when connected to the Core?
StKong:A very reliable option is to connect the IR-eye that borh has physical volume buttons and can be controlled by eg. a Beo4 remote.
To my knowledge, the Core has to be a special version in order to be able to have an IR-eye connected.
Type 3051 Partnumber 1293042 according to another thread on the subject.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I went with the Beosound Essence Remote, thanks for everyone's input.
I bought a from 2nd hand retailer. And I'm wondering if the Remote is supposed to have LEDs that give a visual feedback when clicking the buttons (and mine is broken in that regard) ?
Hereford:I went with the Beosound Essence Remote, thanks for everyone's input. I bought a from 2nd hand retailer. And I'm wondering if the Remote is supposed to have LEDs that give a visual feedback when clicking the buttons (and mine is broken in that regard) ?
