What’s the better remote purely for volume control of BS Core?
This post has 14 Replies | 0 Followers
Hereford
Posts 87
Hereford Posted: Thu, Feb 20 2020 3:06 PM
Essence or Beoremote One BT?
w5bno123
London
Posts 578
w5bno123 replied on Thu, Feb 20 2020 3:11 PM
I would choose a Beoremote 1 every time. It’s very reliable and allows you to select sources as well. If you use TuneIn your favourite radio stations are mirrored on the remote. In time you could use this with other products as you can pair up to 8 Bluetooth devices and it’s also fully backward compatible with legacy IR products.
Regards
Stuart
Hereford
Posts 87
Hereford replied on Thu, Feb 20 2020 3:48 PM
Thanks for your input.
How simple is it when you have just one source? Is it as simple as picking it up and clicking volume down?
Millemissen
Flensborg, Denmark
Posts 14,680
In that case I’d say the Essence Remote might be ideal.
Otherweise I agree with Stuart.
lawrencejmcook
Posts 742
To be precise, Hereford, yes. If your BR One BT is only ever used with a single source device (e.g. Core) you just pick up the remote and hit Volume + or Volume -.
At least that is the way mine works with my BS Essence MkII. It does this regardless of how I have started it playing, whether via Airplay, B&O app or Line In.
But what I prefer about using the Essence remote is the physical feedback via the wheel of how much or little I have adjusted the volume.
Lawrence
Hereford
Posts 87
Hereford replied on Thu, Feb 20 2020 5:21 PM
And the Essence Remote can pair to Core all by itself? It has bluetooth? I’m a bit cautious because I already  made the mistake of buying the wrong Beoremote 1...
Duels
England
Posts 2,553
Duels replied on Thu, Feb 20 2020 6:22 PM
I use the essence remote with the core and it works really well. The volume wheel is cool and very tactile.
It also has the wow factor with visitors who are unfamiliar with B&O.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Feb 20 2020 9:43 PM
... and as you get more sources in your Core, a single press on the Essence remote navigates from one source to the other, change tracks or radio stations, mute or unmute the sound. If you add more NL products later, a single press can also join another experience (multiroom), a long press shutdown all products. In summary, a very simple, efficient and nicely designed wheel that has the wow effect mentioned previously.
StKong
Copenhagen
Posts 320
StKong replied on Fri, Feb 21 2020 2:36 AM
A very reliable option is to connect the IR-eye that borh has physical volume buttons and can be controlled by eg. a Beo4 remote.
Razlaw
Posts 4,345
Razlaw replied on Fri, Feb 21 2020 3:57 AM
I agree that the Essence remote has a wow factor. I wish I did not have to stop using the one I previously used with my Core. But I replaced 20s with 50s and use the volume control in the 50s so can no longer use the Essence remote.
stampfki
Posts 138
stampfki replied on Fri, Feb 21 2020 7:54 AM
Is the wheel more responsive when connected to the Core? With the Essence it’s quite buggy. Soketimes you need to press twice to start listening and volume control is also not smooth at all.
I have a second wheel controlling a Beosound 2 without any issues. So I guess it’s the Essence.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Feb 21 2020 8:27 AM
stampfki:
It happens occasionally that you have to wait 1 or 2 s for the Core to answer to a volume change action, but I have seen that on my BS 1 too
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Feb 25 2020 8:41 AM
StKong:
To my knowledge, the Core has to be a special version in order to be able to have an IR-eye connected.
Type 3051 Partnumber 1293042 according to another thread on the subject.
Hereford
Posts 87
Hereford replied on Tue, Mar 3 2020 11:41 AM
I went with the Beosound Essence Remote, thanks for everyone's input.
I bought a from 2nd hand retailer. And I'm wondering if the Remote is supposed to have LEDs that give a visual feedback when clicking the buttons (and mine is broken in that regard) ?
StKong
Copenhagen
Posts 320
StKong replied on Tue, Mar 3 2020 12:10 PM
Hereford:
Congratulations!
The diodes are only meant to be visible during the pairing process and during choice of option settings.
Page 1 of 1 (15 items) | RSS
