Is it only me that has stability issues with BV Horizon 40?
It happens perhaps 2-4 times per month.
Yes the the TV is fully updated. I have tried to clear the program cache and reboot the TV by holding down the standby button for 20 sec until the logo is shown again.
I am not asking for suggestions to get another TV.
Stability was improved with the update in October but it also required a reset.
It has nothing all to do with responsiveness. When the TV cannot be turned on. It will not turn on at all! Only workaround is to pull out the power cable wait about 15 seconds. Attach the power cable again. Then I can turn it on again. So a quick timer will not solve this. It can only be a bug.
Yes the green light mean in my case that I cannot turn on the TV. In this case the will stay green until I pull the power cable out, wait and attach it again. Otherwise it will stay green for ever. It is when the TV is not in use at all. I have had this issue 3-4 times. I can not even reboot the TV with the remote
I know that the green light sometimes is normal situation, but in this situation.
Still issue with stability. A technician was here. That day he only went through a B&O check list. I had already myself done almost all the same. After that day the TV has restarted 3 times by itself during use.
Hi Pat
1, 2, 3 has been done earlier. Did not remove the issue.
Directly connected to the TV I have:
The Bang&Olufsen head quarter says that there is most like a hardware issue, but the technician they sent are not sure about that. And I do not understand so bad the B&O customer service works. They write to me that there the head quarter says that there is most like a hardware failure, but the technician they sent home to me had not got any information about this. I needed to provide him with the email I have got. And the technician cannot log in the log files! It is scary how it works.
This week two main board inside the TV has been replaced. So I hope this has solved all the issues.
quick start in avant uses 55W of power in stand by, thats not very efficient, I cancelled mine
I do not use quick start so that was not the issue.
