Beosound Core Deezer HIFI
This post has 48 Replies | 2 Followers
jg1976
Posts 63
jg1976 Posted: Fri, Feb 28 2020 5:10 PM
I have just been in contact with Bang & Olufsen support regarding question if Beosound Core supports Deezer HIFI subscription, FLAC format (16-bit, 1,411 Kbps).
I received following answer:
"The built-in Deezer app on the Bang & Olufsen application only supports normal Deezer however via the Deezer app you can stream Hifi using Airplay 2 or Chromecast to the Beosound Core".
I definitely want the HIFI option (I do subscribe on it.. ) since I have connected beosound Core to my Beolab 5 optically.
Anyone else has other information about this or if it is planned/or even possible due to an update for Beosound Core?
jg1976
Posts 63
jg1976 replied on Fri, Feb 28 2020 5:26 PM
I guess this will be of big interrest for many beo-sound-enthusiast out there.. To have the possibility to play with best deezer quality available..
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Feb 28 2020 5:42 PM
That was really strange .... not supporting Deezer HiFi.
All other B&O devices do that.
Can anyone with a Core and Deezer HiFi subscription confirm?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy
Posts 3,972
Beobuddy replied on Fri, Feb 28 2020 6:13 PM
jg1976:
...since I have connected beosound Core to my Beolab 5 optically.
Interesting setup. Did you connect both powerlink (RJ- Powerlink Din) and optical (to COAX digital) simultaniously? Or just optical and another option (1 ) on the BL5?
AFAIK the digital input from the BL5 was only actived when "CD" command was send through the powerlink. But maybe that is only valid when you use the option 0 (factory setting) is used.
Razlaw
Posts 4,345
Razlaw replied on Fri, Feb 28 2020 8:12 PM
I have Deezer HIFI and a Core connected to 50s. I thought I was getting HIFI. This makes me wonder. I will try the Deezer app and airplay and see if I can notice a difference.
jg1976
Posts 63
jg1976 replied on Fri, Feb 28 2020 8:35 PM
Beobuddy: Yes, I read this forum back and forth. But when I came to the solution it was just perfect for me:
Having a masterlink system (cat7 wired throughout the house). A beolink converter nl/ml in the office created another light-zone but also made it possible to add a core in the living room.
Deezer is set to CD in my system, making beolab 5 to automatically listen to optical port, but I can still, and at same time listen to the same source in any other zone in my house (11 zones Unsure).
This was just the perfect solution, when sitting in my livingroom ”listening” to best audio on ”best” beolab 5 speakers I wanted to use coax input of course, but also having Deezer HIFI.
Therefore I was little dissepointed once I received the reply from b&o.. Mayby they were wrong and one can only hope so... Or if there will be an update in very near future..
See my livingroom setup here:
jg1976
Posts 63
jg1976 replied on Fri, Feb 28 2020 8:36 PM
Razlaw: yes, please give your feedback to this.. most appeciated..
Razlaw
Posts 4,345
Razlaw replied on Sat, Feb 29 2020 12:49 AM
My initial impression is that the sound is better from the Deezer app. Will do some more listening tomorrow and see if my opinion is the same.
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Feb 29 2020 12:56 AM
Have someone else switch sources for you, that way you don’t “know” what’s playing, hifi or not.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Razlaw
Posts 4,345
Razlaw replied on Sat, Feb 29 2020 1:16 AM
I do need to that. First will have to train someone how to do that.
danielshen
Posts 78
Dear,
May I know how to set "Deezer is set to CD in my system, making beolab 5 to automatically listen to optical port"? Such setting is in the B&O APP?
Can you give me a screenshot for the Deezer -> CD setting? Many thanks!
Daniel
jg1976
Posts 63
jg1976 replied on Sat, Feb 29 2020 6:27 AM
Danielshen: I set it via beolink converter nl/ml. CD-source is ”Music” equal to start Deezer..
jg1976
Posts 63
jg1976 replied on Sat, Feb 29 2020 6:52 AM
Razlaw: My initial thought for writing to B&O, was that I felt a "different" in audioquality when playing in my office versus livingroom.
Setup in office: Beolink Converter NL/ML, Imac with Deezer app (can handle Deezer HIFI), Beosound 3 connected from 3,5mm output from Imac to the converter line-in...
Millemissen
Flensborg, Denmark
Posts 14,680
Mikipidia:
....and (volume) level match precisely - best using a soundmeter of some kind.
Even a slight difference in the volume level can fool you to think that one is better or worse than the other.
Beobuddy
Posts 3,972
Beobuddy replied on Sat, Feb 29 2020 7:45 AM
danielshen:
That’s done in the setup of the NL/ML converter. Set the ML, CD function to NL, Music function.
w5bno123
London
Posts 578
w5bno123 replied on Sat, Feb 29 2020 10:11 AM
They need to be updated!
I have Deezer Hifi and a shop full of Bang & Olufsen and it is supported. Here’s a screenshot from our Core that’s integrated into a Beosound Shape. If you subscribe to Hifi it automatically detects it and if the file is FLAC it displays it at the top.
In the Google home app I also switch on Full Dynamic Range feature which improves the sound quality.
jg1976
Posts 63
jg1976 replied on Sat, Feb 29 2020 11:40 AM
W5bno123: Thank you for clearing this up. 👍 I hope you are correct and they just need to update the customer service...
Beobuddy
Posts 3,972
Beobuddy replied on Sat, Feb 29 2020 1:12 PM
To be more complicated.
The Core in this setup is integrated with the BV7-55 via the NL/ML converter. So, the music goes through the network to the converter, which transfers it from digital to analog audio. Officially the NL/ML converter isn't, or shouldn't be Deezer HiFi capable.
Connecting the speakers directly to the Core (which might influence settings in software inside Core), the Core definitely is Deezer HiFi capable. Confirmed by my dealer and indicated by the " Flac" sign on the app. On the Deezer app you will see that the HQ indication (when playing on your iDevice changes to " HiFi", when you select the Core.
jg1976
Posts 63
jg1976 replied on Sat, Feb 29 2020 1:25 PM
Beobuddy: Good feedback! Most appreciated.
However if you look at my setup, sound is distributed optically from core directly to beolab5.. So I do not think sound is going to the converter & back in this case. It ceartanly does when I playing from other linkrooms, so you are correct there..
Other than that I do not know what else settings can be done in core. Deezer is just a login option.. No sound-quality-selector there.. Smile
steve1977
Posts 911
steve1977 replied on Sat, Feb 29 2020 6:11 PM
Beobuddy:
OT: interesting setup. Do you airplay via the core to the BV7? If so, does this work if the BV7 is turned off and does it play without turning the screen on?
Beobuddy
Posts 3,972
Beobuddy replied on Sat, Feb 29 2020 6:47 PM
The setup works like a "traditional" setup, like with an Ouverture/BS3000 or any other Audiomaster with ML. In this scenario the BV7 takes the commands through infrared, but the screen stays off. Only the display at the side of the BV7 shows what's playing. Here the NL/ML converter, combined with the Core, replaces the Ouverture/BS3000 and act the same the same way.
If you select CD and the Core starts playing, but you can overrule that by start using Airplay to the Core. You can also start using Airplay to the Core from standby and the converter will trigger the BV7-55 in audiomode (no screen).
steve1977
Posts 911
steve1977 replied on Sat, Feb 29 2020 7:01 PM
Very cool, thanks! Does the BV7 also eventually turn off once the AP2 stream stops?
Beobuddy
Posts 3,972
Beobuddy replied on Sat, Feb 29 2020 7:07 PM
If you stop casting or airplaying to the Core, then after some time, the system will go to standby, yes. The same counts when your playlist has been  played and stops.
jg1976
Posts 63
jg1976 replied on Sun, Mar 1 2020 9:41 AM
I am sorry for taking it up again, however I needed to confirm with Bang & Olufsen Support again, after information I have received from this forum. So I asked following:
Question:
"I have just received different responds from different forums and different Bang & Olufsen Stores regarding if the build in Beosound Core actually supports Deezer Hifi or not.
Can you please confirm what is earlier stated from B&O support: ”The built-in Deezer app on the Bang & Olufsen application only supports normal Deezer”
Answer:
"Thank you for getting back to us
We can indeed confirm what we said earlier is true, the built-in Deezer app on the Bang & Olufsen application only supports normal Deezer however via the Deezer app you can stream Hifi using Airplay 2 or Chromecast to the Beosound Core"
So, please take not to this and please make comments..
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Mar 1 2020 10:33 AM
jg1976:
I really don't understand the above B&O support statement :-(
The B&O app is only a Deezer "controller", not a a Deezer "music player", that is controlling the B&O device's integrated music service, i.e. Deezer so Hifi or not at the app level is irrelevant.
When you have a subscription to Deezer Hifi, that your B&O device is Deezer HiFi capable and that the track you are playing is available in HiFi format, then the B&O app shows the FLAC logo close to the Deezer icon in the now playing screen as mentioned by other members.
jg1976
Posts 63
jg1976 replied on Sun, Mar 1 2020 1:17 PM
Question:
"That being said, so even if i have subscription on Deezer HIFI, log in at Beosound Core with my account, I will not be able to stream higher than normal Deezer?
 Besides then of course to use Deezer’s own app and stream As you stated before"
Answer:
"That is correct the Bang & Olufsen App's Deezer integration only supports normal Deezer playback from the app itself, HiFi is supported via Airplay and Chromecast by your Beosound Core. "
Question:
"Just a last question, why is it stated ”FLAC” in the Bang & Olufsen App when playing from Beosound Core?
As I understand from your earlier reply this is not correct?"
Answer:
"B&O app will indeed showcase that the reproduced file is FLAC as it is being reproduced from a Deezer HiFi account, but unfortunately due to the different bandwith that HiFi Deezer uses and the one that the B&O app can handle, the format will adapt to one that our App is able to stream.
We are sincerely sorry for any inconvenience that this may have caused you."
What is your thoughts about this?
Millemissen
Flensborg, Denmark
Posts 14,680
jg1976:
Seems incredible.
The app handles FLAC over DLNA.
jg1976
Posts 63
jg1976 replied on Sun, Mar 1 2020 1:29 PM
Millemissen: Yes, sounds incredible for me too... Wonder what is going on at B&O..
A quick look at Deezers HIFI own homepage they refer to B&O as brand that all their product will support Deezer HIFI.
Now this makes me wonder... I’ve also asked Deezer themselves a question if they have a specific product-list. No answer yet...
Beobuddy
Posts 3,972
I think the given answer simply isn't correct!
The app doesn't need to handle the stream, but only the information which comes with the music. If you use the app to start the music, you can walk away or shut off your app and the music keeps playing. So, the music doesn'r go through the app. As simple as that.
Bandwidth isn't an issue. Despite the 100Mb ethernetsocket, it has enough margin for Deezer HiFi. Do not forget that Deezer HiFi is the same as uncompressed music, like the stream that comes from a normal CD.
Millemissen
Flensborg, Denmark
Posts 14,680
jg1976:
The device list can be seen here - I guess the Wikipedia has it right:
https://en.wikipedia.org/wiki/Deezer
Besides - as far as I have understood the techology behind how Deezer streaming works, the stream is fetched to the device directly.....the app is merely the control point.
This means, that the ‘ability of the app to handle FLAC’  should not be a question here.
Razlaw
Posts 4,345
Razlaw replied on Sun, Mar 1 2020 6:05 PM
Did some more listening today, Core versus Deezer app via AirPlay and BL50s. Today I do not hear a discernible difference.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Mar 1 2020 9:29 PM
jg1976:
Again, B&O support answer is BS .... Deezer is a device (Core, Moment, A6, BS1, BS2, A6,A9, M5, M3, etc ) integrated music service as written in their respective tech description. B&O App is a controller (start/stop/forward/backward/search/etc..) and is not streaming any Deezer music flow to any device. What the app shows in the now playing screen is what the device’s integrated music service, I.e. Deezer, streams.
Way to demonstrate it: start a Deezer Hifi stream on a product from your B&O app and shutdown your app or even better the device running the app ... streaming continues ? Is it a miracle???
Wolf_70
Posts 31
Wolf_70 replied on Tue, Mar 3 2020 5:13 PM
This topic was very interesting for me. I have a Deezer Hifi account and using the Core.
So I also contact the support. As mentioned in the forum they confirmed that when in the B&O App the symbol is FLAC, than the streaming is in Hifi Quality, see below!
<<Gerne bestätige Ich Ihnen das wenn Sie einen Deezer HIFI Vertrag haben, die obere "FLAC" Angabe heißt dass das Audiosignal "verlustfrei" mit Flac Komprimierung über Beolink (B&O App) abgespielt wird.>>
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, Jun 23 2020 4:58 PM
As I have Deezer HiFi back, i did a small test:
Play a track (Space Oddity 2019 mix) from the Core itself (Deezer service).
Play the same track on the Deezer app running on an iPad streaming AP2 to the Core.
Monitor my ISP network traffic:
Conclusion:
On the left side you can see the Core/Deezer traffic. Shorter in height (kB/s) but longer in time than the right side which is the Deezer app playing the same track, caching the data much more (higher bandwidth usage, shorter time). Looking at the graphs we can easily see that the volume of transferred data is almost the same in both cases. I then assume that the Core effectively leverages Deezer HiFi.
From a listening perspective (I place myself in the sweet spot of my 5 speakers), my old ears do have a preference for the Core/Deezer service v.s. Deezer app/AP2/Core. Sound is sharper and warmer, specially for the bass.
I then listened to the same tack from a LP, 1973 edition ..... sound is even better to my ears.
Sandyb
Posts 2,186
Sandyb replied on Tue, Jun 23 2020 5:36 PM
Thanks for that, interesting.
No surprise that the vinyl was preferable.
Some of my older vinyl from the 70s/80s sounds much richer than streamed files.
mbolo01:
Conclusion:
I then listen to the same tack from a LP, 1973 edition ..... and sound is even better to my ears.
Moningsand
Posts 19
Very interesting test, to see how different they act to optimize their usage of the connection.
Another interesting test would be to play the same song via BS Moment and have your BL18 connected via WISA. If I understand everything correctly, the digital signal would not be converted to analog until it meets the DAC in the speakers. How does that sound compared to BS Core, where I assume you used the built-in DACs.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, Jun 23 2020 6:10 PM
Moningsand:
I can’t do the suggested test, both Core and Moment are wired to a TR 1 doing the WISA job and I have no PL cables to play with.
Curly
FL, USA
Posts 366
Curly replied on Wed, Jun 24 2020 1:48 PM
Am I the only one becoming increasingly irritated with the Core’s lack of built-in support for high-rez streaming? See my other thread on the topic.
Perhaps we should all be getting Bluesound Node 2i’s. Mine arrives today. We’ll see if I can hear a difference in the higher rez music streams.
Just another sad example of B&O’s less than impressive software. Their hardware is the best though! But come on, B&O...
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
Razlaw
Posts 4,345
Razlaw replied on Wed, Jun 24 2020 3:36 PM
Curly:
BeoSound Core, BeoLab 17, BeoLab 18
Please let us know your thought on the Bluesound. I have been considering one also and am also currently using a Core with my 50s.
Page 1 of 2 (49 items) 1 2 Next > | RSS
DigiCert Secured Site Seal
