Wiring up an LC2 as a Wall dimmer
This post has 3 Replies | 3 Followers
Chris Harrison
Peak District
Posts 381
Chris Harrison Posted: Wed, Dec 26 2012 4:53 PM
As the LC2 is supposed to be an inline dimmer. I am having issues wiring it as a wall dimmer.
Got 2 wires going into Live and 1 into Load. How would I wire this to the LC2 of which has 4 inputs?
Thanks.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
YannChris
Larmor Plage - France
Posts 232
YannChris replied on Wed, Dec 26 2012 8:00 PM
Hello Chris,
LC2 has 1 input for Live and 1 input for Neutral.
At the other side are 2 outputs to feed the lamp (Live and Neutral too).
So you need 2 wires of each type.
In addition to the 3 red wires connected to the dimmer, I see 3 black wires in the inwall box, so my guess is that you have the required cabling.
I suggest that you ask an electrician to check this..
Happy new year and kind regards,
Living Room   BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge  Beolink Passive - Cabasse Clipper - Beo4      Kitchen  BL3500 - Beolink 1000
Bedroom    BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge   BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study    BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
kokomo
Spain
Posts 206
kokomo replied on Thu, Dec 27 2012 11:18 AM
Firstly a disclaimer. I am NOT an electrician but have wired all my LC2s myself.
I assume the 1st photo is of an existing setup of non-B&O switch or dimmer?
As it has 3 red live cables connected it seems to be of the type that switches/dims via live feed only.
As previously advised you require both live and neutral in and out of an LC2.
Again I assume the black wires visible are the neutral/negative. Therefore you need to connect one live and one neutral to the 'in' connections on the LC2 and live and neutral out to the lamp you wish to control.
It's all described in the instruction booklet which I assume you don't have.
bayerische
Ekenäs, Finland
Posts 4,770
bayerische replied on Thu, Dec 27 2012 11:25 AM
If you're not an electrician, I wouldn't be tinkering with electricity.
Remember, would there be an electrical fire associated with your home-brew connections your insurance company isn't liable.
Also, some old time electrical master on/off switches did not necessarily kill the live cable, but the neutral. So be careful.
Too long to list....
Page 1 of 1 (4 items) | RSS
