Hey guys,
I have a BL14 5.1 setup but my processor is the connection hub which only enables stereo as far as I am aware. I am mainly using this setup for TV viewing and I would like to use the system to its full capability.
Do you have any recommendations on a processor that can help me make use of the system for as little $ as possible? (and something that is easy to both setup and use)
Cheers,Gunnar
Ahh I see - do you know what cables I would need to hook it up?
Also I can see that the surround amplifiers have different watts based on price levels - would I be skipping the built in amp and downgrade the speakers by choosing a cheap amp that only has say 90 watts per channel?Thank you for the quick response!
Found this one at a good price for instance - https://www.pioneer-audiovisual.eu/sites/default/files/datasheets/english/VSX-534.pdf
