What processor do you recommend for BL14?
This post has 3 Replies | 0 Followers
GunnarE
Posts 3
GunnarE Posted: Fri, Mar 6 2020 11:12 AM
Hey guys,
I have a BL14 5.1 setup but my processor is the connection hub which only enables stereo as far as I am aware. I am mainly using this setup for TV viewing and I would like to use the system to its full capability.
Do you have any recommendations on a processor that can help me make use of the system for as little $ as possible? (and something that is easy to both setup and use)
Cheers,
Gunnar
leosgonewild
Helsinki, Finland
Posts 2,373
Any surround amplifier will do if you have the multicable.
GunnarE
Posts 3
GunnarE replied on Fri, Mar 6 2020 12:34 PM
Ahh I see - do you know what cables I would need to hook it up?
Also I can see that the surround amplifiers have different watts based on price levels - would I be skipping the built in amp and downgrade the speakers by choosing a cheap amp that only has say 90 watts per channel?
Thank you for the quick response!
Found this one at a good price for instance - https://www.pioneer-audiovisual.eu/sites/default/files/datasheets/english/VSX-534.pdf
leosgonewild
Helsinki, Finland
Posts 2,373
This one. It doesn’t matter what amp, as the BL14 sub will make the input signal to line level and amplify it itself.
Page 1 of 1 (4 items) | RSS
