Hello,
I have been offered a Lutron Rania dimmer (B&O version) for Christmas.
It's installed and works well, but I have to make it co-operate with the several LC2s already in place.
I would like to assign it a lamp number in order to integrate it in the scenes involving the LC2s.
I cannot find the advanced settings manual, the web page mentioned in the installation guide is no more in line.
Thanks by advance to all helpful Beoworlders.
Yann.
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
Thanks Martin,
I unfortunately had not high hopes that my idea was possible.
In addition to coulor buttons, the Rania also uses ciffers 1 to 4.
According to what you say, the only solution would be to use scenes 1 to 4 for Rania + LC2s and scenes 5 to 9 for LC2 only.
I already changed the programming of my Beo5 to include the specific power-off command of the Rania in my "All lights off" macro.
Kind regards,
Yann,
Interestingly, if you were to be using a Rania Dimmer which is NOT a B&O version with your Beo5, then you would not have the problem.
Regards Keith....
Keith,
Thanks for the information.
I noticed that adding Lutron Rania in my Beo5 did not bring to any result, so I removed it of the "accessories" list.
The dimmer is there and I doubt that B&O dealers sell non B&O versions.
Kind regards and happy new year,
Yann..
Attached is an XML control file for a Lutron Rania for DIRECT control of a NON B&O Lutron Rania.
Non B&O Lutron Rania are freely available such as from HERE
The attached XML file will NOT work on B&O versions.
Thank you again!
As usual you have the right answer to each question..
Thanks for the XML file and the link.
When compared to to the B&O version, regular Ranias are pretty cheap.
Happy new year and kind regards,
