Lutron Rania - help needed
This post has 7 Replies | 0 Followers
YannChris
Larmor Plage - France
Posts 232
YannChris Posted: Sun, Dec 30 2012 9:56 AM
Hello,
I have been offered a Lutron Rania dimmer  (B&O version) for Christmas.
It's installed and works well, but I have to make it co-operate with the several LC2s already in place.
I would like to assign it a lamp number in order to integrate it in the scenes involving the LC2s.
I cannot find the advanced settings manual, the web page mentioned in the installation guide is no more in line.
Thanks by advance to all helpful Beoworlders.
Yann.
Living Room   BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge  Beolink Passive - Cabasse Clipper - Beo4      Kitchen  BL3500 - Beolink 1000
Bedroom    BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge   BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study    BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
MartinW
Posts 389
MartinW replied on Sun, Dec 30 2012 10:32 AM
Not possible i'm afraid - the LC2 uses number commands to recall scenes, whereas the Rania uses the four colour buttons. Also the LC2 uses 'STOP' to switch the lights off whereas the Rania uses '0'. Just set up scenes you like on both and remember to press the number and colour you want to change. They will all respond to up and down for dimming.
YannChris
Posts 232
YannChris replied on Sun, Dec 30 2012 11:06 AM
Thanks Martin,
I unfortunately had not high hopes that my idea was possible.
In addition to coulor buttons, the Rania also uses ciffers 1 to 4.
According to what you say, the only solution would be to use scenes 1 to 4 for Rania + LC2s and scenes 5 to 9 for LC2 only.
I already changed the programming of my Beo5 to include the specific power-off command of the Rania in my "All lights off" macro.
Kind regards,
Yann.
Barry Santini
New York
Posts 543
On my LC1s, which I use with my Lutron BnO, I have found that scenes 1-4 map to the colored buttons, starting at the 7o'clock position: red=1; green = 2; yellow =3; and blue = 4. The only other difference is the "off": lutron prefers "0": LC1 prefers "stop"
Maybe the LC2 is similar?
B
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Yann,
Interestingly, if you were to be using a Rania Dimmer which is NOT a B&O version with your Beo5, then you would not have the problem.
Regards Keith....
YannChris
Posts 232
YannChris replied on Mon, Dec 31 2012 8:10 AM
Keith,
Thanks for the information.
I noticed that adding Lutron Rania in my Beo5 did not bring to any result, so I removed it of the "accessories" list.
The dimmer is there and I doubt that B&O dealers sell non B&O versions.
Kind regards and happy new year,
Yann..
Keith Saunders
Posts 5,495
Yann,
Attached is an XML control file for a Lutron Rania for DIRECT control of a NON B&O Lutron Rania.
Non B&O Lutron Rania are freely available such as from HERE
The attached XML file will NOT work on B&O versions.
Regards Keith....
YannChris
Posts 232
YannChris replied on Mon, Dec 31 2012 3:45 PM
Keith,
Thank you again!
As usual you have the right answer to each question..
Thanks for the XML file and the link.
When compared to to the B&O version, regular Ranias are pretty cheap.
Happy new year and kind regards,
Yann.
Page 1 of 1 (8 items) | RSS
