Hi Everyone,
I'm planning to switch from wifi to a wired Ethernet connection for my Essence mk2.
Is it just a matter of plugging the cable in, leaving its current wifi configuration as-is? Should I deactivate the wifi connection somewhere in the B&O App ?
Thanks in advance.
mauro
No, you will not need to
My Beosound Essence MK II does not connect to my network via cable.
Wireless works just fine.
Since I have this issue with 2 Beosounds I guess it is either my network or the Beosounds running the same (latest) software....
Any idea where I could find release notes?
Ralf
