BEOSOUND ESSENCE and wired Ethernet connection
This post has 3 Replies | 0 Followers
beolit39
Posts 43
Silver Member
beolit39 Posted: Sat, Mar 21 2020 12:05 PM
Hi Everyone,
I'm planning to switch from wifi to a wired Ethernet connection for my Essence mk2.
Is it just a matter of plugging the cable in, leaving its current wifi configuration as-is? Should I deactivate the wifi connection somewhere in the B&O App ?
Thanks in advance.
mauro
lawrencejmcook
Posts 742
Hi Mauro,
You don’t need to configure anything more. Just plug in the Ethernet cable. That’s how I use mine. Then if I move the Essence around the apartment far from the router, I just unplug the Ethernet cable and it remembers the wireless credentials.
Lawrence
Aussie Michael
Melbourne, AU
Posts 3,730
No, you will not need to
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Jul 1 2021 3:35 PM
My Beosound Essence MK II does not connect to my network via cable.
Wireless works just fine.
Since I have this issue with 2 Beosounds I guess it is either my network or the Beosounds running the same (latest) software....
Any idea where I could find release notes?
Thanks in advance.
Ralf
Page 1 of 1 (4 items) | RSS
