Re-coning speakers? MS150 10" woofers
This post has 3 Replies | 0 Followers
summitp
Posts 5
summitp Posted: Tue, Mar 24 2020 6:34 PM
Any tips or tricks, and sources for materials?   I have 2 10" woofers from MS150 that need to be reconed.
Thanks in advance.
Beo_Jean
QC, Canada
Posts 334
Beo_Jean replied on Tue, Mar 24 2020 8:11 PM
You mean refoamed?  Reconing means you're changing the entire cone which I doubt.
Talking personally, I have a pair of REVOX Plenum B which were refoamed (foam surrounds changed) and the surrounds are way too stiff now as the bass is completely gone.
So be careful at selecting your new surrounds.  I heard only good things about Dr Kurt Muller surrounds.
In case you ask, use foam is foam was, don't use rubber unless you have no other choice.
summitp
Posts 5
summitp replied on Wed, Mar 25 2020 3:59 AM
I refoamed the 8" mids, and I redid one of the 10" woofers with foam supplied by a seller in the Netherlands.   The other 10" woofer has a severely warped paper cone.   Refoaming it will not work unless I replace the cone.   And if I replace one, I want to replace both so they sound the same.
summitp
Posts 5
summitp replied on Wed, Jul 1 2020 6:44 PM
So I have found someone who is going to take a crack at putting new cones and spiders on the 10" woofers.  There is a local place here in Salt Lake City that does recones, and they said they would give it a go.   So.  Dropped them off, I supplied new foam surrounds from goodhifi off ebay (his 8" foams fit the 8" drivers perfectly).   So...   fingers crossed.  I'll update when I get them back.  Hopefully they are like new. and I can put the originals back in the cabinets.
Then I'll have 2 10" peerless drivers that will need a home.  I guess I'll have to build a big sub woofer box for them and get another amp.  hehe.
Page 1 of 1 (4 items) | RSS
