Gazfuller:Hello, regarding essence remotes are they known for issues with the volume wheel not working? I’ve got one where all the faceplace commands work but the volume wheel doesn’t respond, it runs fine on the bearing but I’ve notice some lubrication on it.
Thanks for the advice did you get your working again ever? I’m looking for a spare pressure plate and rubber that are underneath the face plate, also the black back part which holds the batteries mine are damaged and need replacing. TIA
