Hello there,
Been a while since I have posted on the forum, have been having a little issue with my Beolab 6000s.On one of them the sound keeps getting muffled and then coming back to normal. I've tried another tweeter from another set I had but that hasn't rectified the issue, tried different sources and cables but no difference. Is this something any one has experienced? I'm assuming its something related to the amp.
Many Thanks in advance
Hi Ronnie,
I have experienced something very similar. It turned out to be a conector with worn out pins. I probably bent the pins, taking the speaker apart.
Bent them back and it was fine. Maybe worth a try to you as well?
Here a thread with pictures.
https://archivedforum2.beoworld.org/forums/p/38065/292126.aspx#292126
Good luck!
Carlo
Hello Carlo,
Okay thanks so much for this, I'll open it up and see if it is a connection issue.
All the best
Ronnie
