I an wondering if I could modify an old style charger simply by enlarging the contact holes into ovals.
This link might help.
https://archivedforum2.beoworld.org/forums/t/18360.aspx
Beoworld Beocom 6000 page says :- Due to safety reasons the updated handset will not fit table chargers produced before May 2003 or the triangular base station. The risk of having a burst from the line if the handset is placed in the old triangular base station, when using a headset, has forced mechanical change to be made the phone.
Stoobie
Ah OK thanks. I guess there is some filtering in the later base or power supply. I'll borrow one and have a look.
Have a look at this thread, especially Keith's last post: https://archivedarchivedforum2.beoworld.org/forums/t/3160.aspx
I checked my Mk1 and Mk2 chargers and they all produce 5.6V unloaded.
Thank you
