Did you check the fuses?
The input butons should release the off button when pressed regardless if there is power or not.
Looks like tar on the input buttons so don't be surprised to find some also into the button mechanism...
The buttons move in a "slow" grease, that gets slower over the years up to the point of being extremely sticky.While pressing in one of the source buttons carefully pull the OFF button out and the switch inside should switch on.
The pushbuttons will pull right off, and then you can clean them and their slider plates.
Wow, I wish I lived on a street where folk threw out B&O
Beocord 1200 and Beomaster 1700 type 1701
