I have tried to find the answers to this but struggling to find anything.
I have a a beosystem 2 controlling a beovison 4-42 TV. I want to be able to use my beo 4 remote to control a Sony DVD player (RMT-D187P). I cannot find anything in the connections list that is remotely similar to this. I understand that this list can be updated to include new products but I cant find any info on how to do this.
Can somebody please explain how this is done. I am competent with electronics and I'm not afraid of having take stuff apart. Just really don't want to have to get a technician out as the equipment is all on a boat that is constantly on the move and it all becomes logistically difficult.
Any help much appreciated.
Are there any Sony DVD players on the list? Sony is unusual in often keeping many of the same codes. If not, you will need a new software chip or the software update program which only a dealer has easy access to.
Peter
no, nothing Sony at all.
wmartin:I have a a beosystem 2 controlling a beovison 4-42 TV.
The BeoSystem 2 is just a modified "Avant Chassis" for plasma displays.Those days B&O had their own DVD1 and later the DVD2 - that's why you can't find DVDs from other manufactrurers on any of these old PUC/STB-TABLES. PS: Updating this chassis can't be made using the service tool to update the SW, it's done by exchanging an EPROM (beeing pre-programmed at B&O).As far as I remember, for a short time B&O manufactured an external DVD controller for some NON B&O DVD-player ...
Vienna: As far as I remember, for a short time B&O manufactured an external DVD controller for some NON B&O DVD-player ...
I have one of those somewhere - it is a modified Scart lead - I used it with a Panasonic recordable DVD player - works quite well. Limited players listed though. Had a quick look and there are 3 Sony players listed as well as the manuals on site.
Vienna:As far as I remember, for a short time B&O manufactured an external DVD controller for some NON B&O DVD-player
This is correct, but it would only work with certain Panasonic or Philips players
Regards Keith....
I have found the full list of DVD players supported by the DVD Controller Mark II as shown below:-
Onkyo DV-S525 02 Panasonic DMR-E50 06 Panasonic DMR-E53/DMR-E55 07 Panasonic DVD-A360 01 Panasonic DMR-EH54D 16 Philips DVD950 00 Philips DVDR70/DVDR75 03 Philips DVDR80 04 Philips VR200 09 Philips HDRW720 13 Pioneer DVDR-3100 05 Pioneer DVR-530H/DVR-630H 15 Sony RDR-GX3/RDR-GX7 08 Sony RDR-HX1010 17 Sony RDR-GX210
The DVD controller can only be configured once as this is burnt into its memory. Once you have configured with one code it is not possible to re-configure it for anythinmg else.
Opman
Thanks for all the info. Has cleared a lot of things up. Think that the easiest thing to do will be to just get a DVD1 as has been suggested.
