Connecting to Beolab 18 speakers without using BeoSound Moment.
This post has 6 Replies | 0 Followers
Nour Addine Ayyoub
Cape Town
Posts 8
Nour Addine Ayyoub Posted: Sun, Apr 19 2020 10:02 AM
Unfortunately I don't like my Beosound Moment. It's slow, doesn't have airplay, is unpredictable, not user friendly and I am currently using it as a glorified Bluetooth device to play music from my phone.
Even just connecting with Bluetooth is a mission sometimes.
Is it possible to remove the Beosound Moment and use something else to play music to my Beolab 18 Speakers and my BeoLab 11 Subwoofer?
Kind regards
Jaffrey2230
Washington DC
Posts 520
You could connect it to a BeoSound Core, which in my opinion is a solid product and even better with an Essence remote if you want to stay with B&O’s system/app or AirPlay 2, Chromecast etc. If you just want to attach your speakers for a good solid AirPlay 2 wireless streamer then you can get a 2nd gen AirPort Express. You will need an adapter. The AirPort Express is around $50 on eBay. If not, you can use something like the BlueSound Node 2i.
I have all three and my preference is for the Core because it has a slightly better SQ (since I use it’s DAC processing) but not much. It is rock solid in my experience. The Node 2i is also good buy slightly more bulky and at a similar price as a Core doesn’t offer any extra benefits. It’s great if you want to connect them to non active speakers so you won’t be using it’s amp for the BL 18.
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
Nour Addine Ayyoub
Cape Town
Posts 8
Thank you and what a good suggestion
mseverg68
Milano
Posts 53
mseverg68 replied on Tue, Apr 21 2020 4:13 PM
Can 2 beolab 17 be added to the core? (in addition to BL18 and BL11)
Jaffrey2230
Washington DC
Posts 520
I believe you can by using a splitter for the Power link on the Core. For questions like this, I'd go with Steve from Sounds Heavenly.
B&O in my life 😊:
Razlaw
Posts 4,345
Razlaw replied on Wed, Apr 22 2020 12:04 AM
In theory, I think you might be able to connect one pair of speakers to the Core by PowerLink and a second pair to the Core using the optical connection. But if you connect two pairs, there would be no way to control the two pairs independently of each other.
mseverg68
Milano
Posts 53
mseverg68 replied on Wed, Apr 22 2020 10:52 AM
Many thanks!
Page 1 of 1 (7 items) | RSS
