I got my hands on a "dead" Beosound 8.
Opened it up - And noticed that there was no power on 5V pins. Found that a section of exposed pcb trace was missing.(no idea how/why). Put a jumper wire and 5V is good now.
Ipod on 30pin connector does not get any response. No charging..no green status.
connecting line-in and playing music - lights up the green status led. But no sound from speakers.
The keypad responds to remote and keypresses (light on keypad activated).
but NO sound from speakers.
Any guidance ?
Thanks !!
Hi dahiyas, were you able to fix your problem?
Everything was working fine with mine, I ordered a 30 pin bluetooth receiver and when I tried it nothing happened, no green light, no orange light, the speaker was dead. I plugged something via line, it works but once I try to use my iPod on the dock the speaker dies completely.
I opened everything to check the connections and cables, there is nothing loose or broken.
I don't know what could be interfering with the iPod dock.
That's a bummer...
Do you have any plans for it, maybe part it out?
