Beosound 9000, Eclipse and AirPlay 2
This post has 22 Replies | 2 Followers
thorne
Posts 315
thorne Posted: Tue, Apr 21 2020 3:58 PM
Hi
if I play a CD on my 9000 (which does not have Airplay 2, obviously), and play it through the Eclipse, which does have Airplay 2, will that CD be available to all Airplay 2 speakers. If so, how do I make that work?
1990
Posts 521
1990 replied on Tue, Apr 21 2020 5:07 PM
No, unfortunately you cannot “feed” anything to AirPlay 2. Playback must start from an iDevice.
You can of course multiroom it via NL, but then you can only use B&O speakers. Not generic AP2-speakers.
thorne
Posts 315
thorne replied on Tue, Apr 21 2020 10:55 PM
Understood. Thanks
so no workaround?
thorne
Posts 315
Understood. Thanks
so no workaround?
thorne
Posts 315
Understood. Thanks
so no workaround?
thorne
Posts 315
Thanks. Understood. So no workaround?
trackbeo
Posts 644
trackbeo replied on Wed, Apr 22 2020 12:50 AM
Kludge workaround: Repurpose an ancient Mac computer to the task.
Rogue Amoeba makes an application called "Airfoil" which can redirect any "Audio Device" to any combination of Airplay and Airplay2 speakers.  Take the Powerlink output of the 9000, route it to the Line In jack of the (old, remember, they have a line in jack!?!) Mac, and set Airfoil to send that to whatever Airplay device.  (Airfoil "Audio Device" also includes Mac OS programs, but we're not interested in that, even though it's the main point of the product!)
Download it for free first, from rogueamoeba.com, just to make sure it runs on your Mac, your old OS, and actually works with the Line In jack.
Edit: Of course, this *completely misses* what makes the integrated B&O system so good: You cannot "join" from other speakers, nor can you control the 9000 via the TV or anywhere else other than its own IR receiver (and panel/edge buttons of course).  You can't wander into another room with another TV and press "Link CD", none-o'-that.  Also changing the speaker groups is a hassle if you have to remote-control your Mac with an app to get Airfoil to swap speakers.
(Generally speaking, Apple was only licensing Airplay *output* devices, and you needed an Apple device to act as source device.  That's the case for this workaround too.  Hopefully this will change sometime soon, with manufacturers being allowed to act as a source as well as a destination.  But not today.)
thorne
Posts 315
thorne replied on Thu, Apr 23 2020 7:26 AM
Thanks, trackbeo, that’s really helpful
matador43
Posts 1,373
matador43 replied on Thu, Apr 23 2020 8:23 AM
trackbeo:
What I dont get, is why there's no substitute!?
Airplay is an Apple patend, but if I understand well "music over wifi" is not: NL, Sonos, maybe others?
Why isn't there somewhere around little magic boxes which TX and RX music over a network?
Millemissen
Flensborg, Denmark
Posts 14,680
Because Apple does not want it to be.
Or because noone has - untill now - knacked the codes to make such a product possible (which I guess at the moment would be illegal).
matador43
Posts 1,373
matador43 replied on Thu, Apr 23 2020 11:01 AM
I meant "not necessarily" Airplay !
As written, Sonos stream audio over network, B&O does the same through NL.
Shouldn't be too difficult to stream audio over a private or common network and have small AD/DA converters at each ends.
Sandyb
Posts 2,186
Sandyb replied on Thu, Apr 23 2020 11:12 AM
Shouldn't we also add Denon's HEOS system, or Bluesound products too, and I'm sure there are others, Roon etc.
B&O's decision to withdraw NL should be seen in that context - that there quite a few other home streaming platforms.
matador43:
Millemissen
Flensborg, Denmark
Posts 14,680
The OP asked for a solution utilizing AP2!
How Sonos does things I can’t say.
B&O however offers a solution (which they are about to ditch), where you can distribute the sound from an AP source to the other speakers in the NL network - I use that from time to time.
But that is not AP2.
IMO there is no need to invent something - it is already there with the B&O NL devices.......with AD and DA converters built-in.
But maybe you are thinking of a small device with just in- and out-put (no speakers etc built-in), that could work on the NL network with whatever source and speakers you’d connect to it?
thorne
Posts 315
thorne replied on Thu, Apr 23 2020 2:02 PM
Hi  Millemissen
This question has taken on a life of its own, which is great. I am reasonably tech savvy but some of this stuff I don’t understand
My set up is Beosound 9000 linked to Eclipse, but not by a converter, Apple TV4, linked to Eclipse in the living room, and Apple Homepod in the conservatory
So if you say what I need is already there, how do I get to hear my 9000 CDs on my HomePod?
AD and DA converters?  Not a clue!
1990
Posts 521
1990 replied on Thu, Apr 23 2020 2:09 PM
How did you connect the BS 9000 to the Eclipse?
Sandyb
Posts 2,186
Sandyb replied on Thu, Apr 23 2020 3:35 PM
He didn't mean your setup is "already there" to do what you want.
With your 9000 connected to your Eclipse, no easy way to listen on your HomePod.
If you HomePod was a B&O speaker, like an M3/M5/ BS1/2 etc etc, it would be all there and a touch of a button (i.e. the NL protocol).
thorne:
Hi  Millemissen
thorne
Posts 315
thorne replied on Thu, Apr 23 2020 4:29 PM
Not sure. B& O set it up. I know it wasn’t a nl/ml converter because it was no longer being produced. Some sort of AV link?
Millemissen
Flensborg, Denmark
Posts 14,680
thorne:
Probably just connected to the analog line input on the Eclipse/SoundCenter.
(How do you control the setup, when playing from the 9000?)
In short - there is no way that you can listen to the 9000 on your Homepod (via AirPlay).
Jaffrey2230
Washington DC
Posts 520
That is right. The Eclipse is an AirPlay 2 receiver. The originator device must be an iDevice to play it on your HomePod. Not sure if you replaced your HomePod with a BeoPlay M5 would change anything...
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
Sandyb
Posts 2,186
Sandyb replied on Thu, Apr 23 2020 7:06 PM
Yes it would.
He'd be able to tap the M5 and it will join the 9000 playing through his Eclipse.
A point you should appreciate now that it has been explained numerous times on the other Airplay threads.
Jaffrey2230:
thorne
Posts 315
thorne replied on Thu, Apr 23 2020 10:30 PM
Thanks for all replies. I realise now it’s not going to happen. Thought I’d ask anyway
thorne
Posts 315
thorne replied on Sat, Apr 25 2020 11:17 PM
Just a thought. Would connecting an Apple airport express to my 9000 allow me to stream CDs to my HomePod?
trackbeo
Posts 644
trackbeo replied on Sun, Apr 26 2020 2:03 AM
Alas not.  Like the speakers, the Airport Express is only an AirPlay *Receiver*.  Its audio connector is line-out, not line-in.  Your only option is line-in on a Mac (Mini, simplest) running AirFoil.  (Of course connecting an Airport Express to the 9000 would allow you to AirPlay *to* the 9000 via Aux In!:-)
Page 1 of 1 (23 items) | RSS
