Your BV10 must set up to a Beo 4 with Navigationbutton to work with a BR1 perfectly
Page 32 in the User Guide
https://www.bang-olufsen.com/en/product-support/Television/beovision-10
Beozip: Your BV10 must set up to a Beo 4 with Navigationbutton to work with a BR1 perfectly
.....and that choice in the menu - if I remember correct - depends on the sw version of the BV10.
