Beosystem 5500 with CD 50 and beogram 3300?
This post has 1 Reply | 0 Followers
thomas1
Posts 1
thomas1 Posted: Sun, Jan 6 2013 6:11 PM
Hello,
Firstly those who have the master controller 5500 and a cd50, are you able to control the CD 50 like the later CD5500, i.e. able to choose which tracks you want?
Secondly, can the master controller operate all the functions on a  beogram 3300 like advancing the tonearm?
Thanks for your help!
Ricardo
Moonbase 5
Posts 418
Ricardo replied on Sun, Jan 6 2013 7:18 PM
Yes the Cd50 functions should work the same as the Cd5500. I belive the datalinking for Beogram 3300 record deck is also compatible with the data codes in a BS/MCP 5500.
It should work and communicate just fine
Page 1 of 1 (2 items) | RSS
