Hello,
Firstly those who have the master controller 5500 and a cd50, are you able to control the CD 50 like the later CD5500, i.e. able to choose which tracks you want?
Secondly, can the master controller operate all the functions on a beogram 3300 like advancing the tonearm?
Thanks for your help!
Yes the Cd50 functions should work the same as the Cd5500. I belive the datalinking for Beogram 3300 record deck is also compatible with the data codes in a BS/MCP 5500.
It should work and communicate just fine
