Hey guys, hope you're all doing well. I had an account here a while back, but I've forgotten my info so I had to make a new account. In the past this forum was pretty helpful, so hoping it still is.
I was just wondering what you guys think about the Beolab 5000 wall speakers? They're an older piece so I know they're hard to find, but if you have them or have heard them I'm wondering about your general impressions especially their sound quality. I've been thinking about getting them, but their uniqueness make them a tough placement.
Thanks in advance.
Have a set in the bedroom and they are great.
Sound is warm and very easy to listen to.
I wouldn't hesitate getting another pair if I had the room.
Peter
I think they look amazing. From what I know you can only place them on a wall - that's the only placement I have ever seen of 5000s. If I recall you could get them powered or not. Either way they are easy to drive and from what I recall sounded similar to 6000s so no necessarily great for deep bass but a good refined sound for general distortion free listening :)
B&O in my life 😊:
I found this picture in www with a floorstand as a DIY job ....
These floor stand ideas keep making the rounds every now and then. I suspect the speakers have no bass at all when not mounted on a wall.
--mika
tournedos: These floor stand ideas keep making the rounds every now and then. I suspect the speakers have no bass at all when not mounted on a wall.
I once did that......ages ago.
Using the stands from the BS 9000.
As I remember it, there was very little bas - so the project was soon cancelled.
The BL5000’s need the wall.....definitely.MM
Thank you all for your input. Sorry I couldn’t respond earlier, I couldn’t access my account.
