Beogram 4000 motor
Inigo71
Posts 4
Inigo71 Posted: Fri, May 22 2020 9:12 PM
Hi.
I am restoring a Beogram 4000 and everything works great but I have two issues.
1. The lamps of the speed potentiometers are very dimm I can only see them when the room is completely dark, is that normal is it how it is suppose to be?
2. The motor makes a mechanical noise, like a tac tac, is it possible to repair the motor or is it possible to get a used one in nice condition? anyone has one?
Thanks in advance for your support
Sincerely
Filip
Copenhagen, *Denmark
Posts 72
Filip replied on Mon, Jul 6 2020 5:27 PM
1) check the bulbs under the control panel. Maybe they need to be bent a little towards the red plastic “screws”.
2) adjust the voltage for the motor until it stops with the knocking sound.
Hope that helps
Inigo71
Posts 4
Inigo71 replied on Mon, Jul 6 2020 7:56 PM
Hi Filip.
Thank you for your reply.
I finally decided to replace the lights with an led plus resistor so the light is dimmed but are more visible than the original ones.
Regarding the motor I set it as stated by the manual, but I can try to adjust in different positions.
Thanks again for your reply
sonavor
Texas, United States
Posts 3,732
sonavor replied on Mon, Jul 6 2020 10:18 PM
The motors can start to knock as the infused oil is depleted from the bearings.
I have my motors restored by Beolover
-sonavor
Page 1 of 1 (4 items) | RSS
