Hi.
I am restoring a Beogram 4000 and everything works great but I have two issues.
1. The lamps of the speed potentiometers are very dimm I can only see them when the room is completely dark, is that normal is it how it is suppose to be?
2. The motor makes a mechanical noise, like a tac tac, is it possible to repair the motor or is it possible to get a used one in nice condition? anyone has one?
Thanks in advance for your support
Sincerely
1) check the bulbs under the control panel. Maybe they need to be bent a little towards the red plastic “screws”. 2) adjust the voltage for the motor until it stops with the knocking sound. Hope that helps
Hi Filip.
Thank you for your reply.
I finally decided to replace the lights with an led plus resistor so the light is dimmed but are more visible than the original ones.
Regarding the motor I set it as stated by the manual, but I can try to adjust in different positions.
Thanks again for your reply
The motors can start to knock as the infused oil is depleted from the bearings.I have my motors restored by Beolover
-sonavor
