I have a Beolink Converter NL/ML that refuses to follow any of the setup commands .
The status LED continues to flash green from the moment power is switched on to, going through the setup for factory reset - press setup button, count 5 red blinks, release, press within 3 secs, orange led and then back to blinking green.
btw - the green flashing rate is always same..no change in speed for any operation.
Have tried -
1. With nothing but power connected.
2. Power and network connected - to computer directly.
3. Power and network connected - to network directly. (DHCP)
Read through the manual and couldn't find anything useful.
Any suggestions please ?
Thank you..am glad things worked out for you.
I had given up yesterday and switched of the unit and tried again this morning after 12 hrs..nothing connected ..same thing..the moment you apply power..green light starts blinking...
It seems like a PC with disk crashed..there is power but no software to boot the hardware.
Hope this doesn't turn into a expensive paperweight :-(
You mentioned about the switch being bad - Was it the setup switch ?
dahiyas: You mentioned about the switch being bad - Was it the setup switch ?
Got it. Yes, I have tried brand new CAT7 cable (tried to follow all requirements in the installation guide), setup a standalone network..
No luck.
Have written to Beocare..let's see what they come back with.
Thanks Pat..How much does the PCB cost ?
I assume that's the small PCB connected with two ribbon cables ?
Thanks Pat.
I got a quote of 945 USD !! So looks like I have a expensive teacup coaster for now
Would you happen to know the part no. ?
Thanks,
Issue with a used 1890 model.
The green light is blinking for about 1 minute and then shut off. Is this a normal behaviour? or should the light stay solid green?
When the button is pressed, whenever the number of blink always get the same results: 5 and half red blink and then no orange light or confirmation when the button is pressed within 3 second to reset for example (here I was waiting for 7 blink).
I was expecting a number of blink equivalent to the number of red blink before the button is released.
